When i turn it on, the light dims in the room, and if i hold down the power button, after a few seconds there is an audible click from inside.
  • 1,557 Answers
The click is the power safe relay opening to shut of power to the pcb before it blows up. As is the lights dimming its crossing power there is a bad short in the amps pcb it needs a tech to look at it When i turn it on, the light dims in the room, and - 10_3_2013_2_18_35_am.png
Posted on Oct 03, 2013
futurework
  • 70 Answers
SOURCE: I've had the same
Sounds like the unit is set to shutdown if it detects a short in the amplifier. The problem can be within the supply but it is most likely in the amp section of the unit. Transistors will go out over time and need to be replaced. Find a local repair shop and have them estimate the repair for you. the cost on something like this can be in the 70.00 range depending on shop rates in your area and the extent of the problem.
Posted on May 04, 2010
Kimi
  • 277 Answers
SOURCE: Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Posted on Nov 27, 2005
SOURCE: Receiver won't turn on. All I got is the flashing light.
Try pushing these buttons at the same timwe for a few seconds:
Advanced Surround + Enter..
'Advaned Surround' will be found in the front panel and 'Return' near the multi-jog dial.
cheers
Mohammed
Posted on Mar 17, 2008
sserpentio
  • 88 Answers
SOURCE: RECEIVER WILL NOT TURN ON.
first you have to test separatly your speakers outputs
disconnect all wires speaker and speakers, turn on your reciever and look if you still have the same problem «CHECK SPEAKER WIRES alert» if yes you have to go to a specialist to fix it... if no test one line after one line with and without speaker connected until the problem reappear to locate the bad line or bad speaker.
Posted on Apr 26, 2008
palaboy
  • 5807 Answers
SOURCE: yamaha htr-5460 receiver; unit will
I just hope you have read my earlier post if not I will post again
Posted on Sep 24, 2010
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Dim light but wont turn on fully
You will need to "reboot"
While pressing down the Nook button (upside down u on the front of the tablet), press the power button on the side. You will need to hold it for couple of seconds.
Mar 07, 2014 | Barnes & Noble Nook HD
Lenovo laptop shut down and will not turn on. Tried removing all power and holding down power button but didn't work. When I press power button the te button lights up for a few seconds then goes out. ...
disconnect the adapter +battery HOLD THE POWER button by 30 seconds aprox, this trick is by eliminate all ESD.
Try again connecting the adpater +battery, if work is o.k
If the problem persist, connect only the adapt and see if the computer work, if does , connect the battery, if work is o.k .if doesnot.
The battery is faulty, RUN the software diagnostic with the adapter and see what going on inside of computer, the power supply inside can be faulty or the battery.
As a last trick, open the battery take out the small battery for CMOS, by 20 seconds. And turn on the computer can be TURN on.
God bless you
Jun 23, 2013 | Computers & Internet
Reseat weast ink canonmp280
I have a solution
1: turn off printer
2: Whilst pressing down stop/reset button (denoted by triangle inside a cycle) press the power button and hold down stop/reset button until power light comes on, continue to hold down power button and release stop/reset button
3: Continue to hold down power button and press stop/reset button 6 more times, alarm light will toggle on and off as you do this
4: Release all buttons , printer has now entered service mode of operation
5: download service tool v1074
6: towards the top of the page find the "clear ink counter" section and click on the "main" button now scroll down page to find "ink absorber counter" on the left and to the right of that "counter value" ensure ink absorber counter box reads "main" and counter value reads "0" now click the set button to the right of the counter value box.
Also
7: the printer will now make some noise and will print out a page of paper, you will also get a couple of prompts on your computer screen telling you a process has been completed just click on the prompts.
8: once that is complete turn the printer off wait a few seconds and turn it back on and your back in business, at least I was, I hope it works for you also - canon printer service
http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MP280 All-In-One InkJet Printer
It has stopped-no current at all. Plugs seem to be OK.
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 16, 2011 | Breadman Kitchen Appliances - Others
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
When I plug in my Breadman Ulitmate TR2500BC bread maker, the light from inside the unit turns on, however, the beep that is made when the unit is plugged in did not sound, the red light on the top is not...
Sounds like you may have left it plugged-in during a lightning strike and/or power surge. Such events can permanently damage the circuitry. That's why most breadmaker instructions tell you to unplug the unit when you're not using it.
Just the same, try the following steps to see if you can restore function:
Reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button instead. Others require you press and hold the Select button instead.
Hope This Helps!
Jun 14, 2011 | Breadman TR2500BC Bread Maker
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Dell AXIM Screen
First, to dim/undim the screen, hold down the power button for a few seconds. A quick press will turn it on/off. Also, when dimmed, if you tap the screen, it should be fully lit. FYI...to change the brightness in either the plugged-in or battery mode, hold in the scroll dial on the left-hand side and press the navigation button (big round one on the front) either up (brighter) or down (dimmer). As for the time, tap Start >> Settings >> System (tab) >> Clock and see if your time is off by 12 hours.
Sep 14, 2005 | Dell Axim X50 Pocket PC
77 people viewed this question
 Grubhead
Grubhead
