Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
Exe remove How on earth do i remove a issassr.exe that is causing havoc on my system? Three different security software has claimed to have removed it over and over and the red warning that's its there still pops up.
  • Microsoft Master
  • 17,093 Answers
There are processes that you have to use to keep it from coming back, first you should turn off restore points. This will flush all the restore points out that you have, then you should boot to safemode and run the scanner to clean it. Then reboot and turn the restore points back on.
Posted on Jul 14, 2013
5 Suggested Answers
SOURCE: My mobile got affected by one file named 'system.exe' wht I do?
Rename 'system.'
Posted on Jan 28, 2009
  • 489 Answers
SOURCE: removing csrcs.exe virus
What you are referring to is probably the W32.Harakit virus. You can find removal instructions here:
http://www.symantec.com/security_response/writeup.jsp?docid=2008-102011-5014-99&tabid=3
Posted on Apr 06, 2009
mastercharlo
  • 51 Answers
SOURCE: How do I remove good.exe virus
You can remove the virus using Sophos antivirus. if u cant get sophos antivirus, u try to repair the vista using vista os cd to repair at startup. It will b ok
Posted on Nov 14, 2009
  • 113 Answers
SOURCE: I have been warned that
You need legal software...
Windows has two control: When you install windows: WPA. It is illegal to crack it with AntiWPA3.cmd patch or something similar.
You have second problem: WGA. It is illegal to remove it with RemoveWGA.exe tool.
I don't know why people can find this program on www.softpedia.com to download.
Posted on Aug 23, 2011
Multiple errors after installing dvd,gps unit,ABS, overheating drive train,stability control plus more
The first step here is to remove the dvd and restore the system to as was. use a code reader to reset the CPU. The electronics of a vehicle are balanced and any power reduction to a sensor or a power increase or an earth through a sensor will cause havoc . Talk with a electronics /radio installer and find out what was done wrong
Dec 15, 2013 | 2010 Mitsubishi ASX 1.6
I am trying to get rid of the xp home security 2011 virus.
Manual Removal:
1. Press Ctrl+Alt+Del on keyboard to stop process associated to "XP Home Security 2011?. When Windows Task Manager opens, go to Processes Tab and find and end the following process:
(random characters).exe
2. You need to update your installed antivirus application to have the latest database.
3. Thoroughly scan the computer and any detected threats must be removed. If removal is prohibited, it is best to quarantine the infected item. Manually locating and deleting of malicious files should also be performed. Please see files below that are related to XP Home Security 2011 Virus.
4. Registry entries created by XP Home Security 2011 must also be remove from the Windows system. Please refer below for entries associated to the rogue program. [how to edit registry]
5. Exit registry editor.
6. Get rid of XP Home Security 2011 start-up entry by going to Start > Run, type msconfig on the "Open" dialog box. A windows containing System Configuration Utility will be launched. Go to Startup tab and uncheck the following Start-up item(s):
7. Click Apply and restart the computer.
XP Home Security 2011 Removal Tool:
In order to completely remove the threat from a computer, it is best to download and run Malwarebytes Anti-Malware. Sometimes, Trojans will block the downloading and installation of MBAM. If this happens, download it from a clean computer and rename the executable file before executing on the infected computer.
Using Portable SuperAntiSpyware:
To thoroughly clean a computer, it is best to do a separate scan of another security program so that other infected files not detected by anti-virus application can be remove as well. Download and run SuperAntiSpyware Portable Scanner.
Apr 06, 2011 | Computers & Internet
How to remove the parasite variant cftmon32 .exe and Ati hot key poller in system32.. HJT v 2.0.0.2 fixes them but they return after 2 or less subsequent scans. Ati hot key poller in system32. always...
cftmon32.exe is a malicious code created to change security processes and registry files and execute different malicious behavior on your computer. Once installed on the PC, cftmon32.exe may automatically carry out mischievous payloads at system start up by creating entries in registry. cftmon32.exe my compromise your privacy and slash computer security.
Follow the given steps for removing virus
1. Temporarily Disable System Restore, Reboot computer in SafeMode
2. Locate CFTMON32.EXE virus files and uninstall CFTMON32.EXE files program. Follow the screen step-by-step screen instructions to complete uninstallation of CFTMON32.EXE.
3. Delete/Modify any values added to the registry related with CFTMON32.EXE,Exit registry editor and restart the computer
4.Clean/delete all CFTMON32.EXEinfected file(s):CFTMON32.EXE and related,or rename CFTMON32.EXE virus files
5.Please delete all your IE temp files with CFTMON32.EXE manually,run a whole scan with antivirus program
Aug 19, 2010 | Microsoft Windows XP Home Edition Service...
My OS is XP. It became infected with the internet
Internet Security 2010 manual removal:Kill processes:
IS2010.exe 41.exe winlogon86.exe winupdate86.exe help.gifHELP:
how to kill malicious processes
Delete registry values:
HKEY_CURRENT_USER\Software\IS2010
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Internet Security 2010"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run "winupdate86.exe"
help.gifHELP:
how to remove registry entries
Unregister DLLs:
winhelper86.dll
help.gifHELP:
how to unregister malicious DLLs
Delete files:
IS2010.exe 41.exe winhelper86.dll winlogon86.exe winupdate86.exe Internet Security 2010.lnk help.gifHELP:
how to remove harmful files
Delete directories:
C:\s
C:\Program Files\InternetSecurity2010\
Jan 28, 2010 | Microsoft Windows XP Home Edition
Windows cannot find file csrcs.exe
File csrcs.exe is located in the folder C:\Windows\System32.
Program has no file description. The file is not a Windows system file. The application is loaded during the Windows boot process.
The program is not visible. It is an unknown file in the Windows folder. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to monitor applications, hide itself, record inputs, manipulate other programs. Therefore the technical security rating is 86% dangerous.
It simply means, "It is very dangerous"
Try these steps to remove it.
Click on START-RUN,
type regedit (it will open the registry editor)
Press Ctrl+F
type "csrcs" (without quotes) and click on Search It'll show you some results, where you'll find "csrcs.exe" delete it immediately.
Again do the same search you may see "explorer.exe csrcs.exe" , right click then modify and remove the csrcs.exe part (leave the explorer.exe as it is)
Hurray !!! you have removed csrcs.exe
Restart your system and see it for yourself
Don't forget to give feedback
Sep 05, 2009 | Computers & Internet
P.exe
P.exe is identified by most Antivirus firms as a trojan/malware which tries to download a malicious file. It has moderate to low damage potential.
You can try and remove this file by downloading Antivir removal tool from: http://www.avira.com/en/support/antivir_removal_tool.html
Also, you can try to scan with Windows Malicious Software Removal tool, download it from: http://www.microsoft.com/security/malwareremove/default.aspx
Also, keep your AV softwares always updated.
Hope this solves your problem. Thanks.
Jul 20, 2009 | HP Compaq ProLiant ML370 G3 Server
Reset secure clock
Cause and Solution to Secure Clock Error
First thing you need to do is open up your task manager by clicking control alt delete.
Select the tab "processes." In the process tab you will see a list of programs that are currently running, if you locate a file called csrss.exe it could be a trojan virus that is blocking your subscription music from communicating with your computer properly. It also effects a lot other things including hardware, personal information, security, etc. but for this post we will keep it specificly on the secure clock error. This csrss.exe trojan/virus causes your computer's internal system to not function correctly including the secure clock.
NOW WAIT! There are two different csrss.exe files, a good one and a bad/trojan one. All windows computers have a csrss.exe file on them and this "good" csrss.exe file is need in order for your computer to run propertly so don't do anything with it until you determine if you have the "good" one or the "bad" one.
You must first determine whether the csrss.exe file that is running on your computer is the "good" one that ships with the computer (inside your systems32 folder) or whether you have the trojan/virus csrss.exe file infecting your computer and secure clock.
Since the systems32 program and the Trojan/virus are both name csrss.exe you must run a quick test to see if you have the bad one or the good one or both.
First locate all fo the csrss.exe files inside your "processes" tab inside task manager (you may have more then one). The way to tell if you have the trojan or "bad" csrss.exe is by right clicking on it and selecting "end task." If you have the "good" one then you should get a windows pop up message. If you you get the windows pop up message, do NOT "end" the task, just ex out or cancel out of it. You do not want to end the "good" csrss.exe file because it is needed in order for your computer to work properly. If you "end task" on the good csrss.exe file then your computer will instantly crash (since it is needed to run).
If when you right click on the csrss.exe file and select "end task" you do NOT get a windows pop up then you may very likely have the csrss.exe trojan virus. In addition to the right click test you may want to simply look at where this file is located. If it is in your systems folder it is the good one, if it is anywhere else it is propably the bad one.
The trojan/virsu version of this csrss.exe file interferes with many of the communication hardware,drivers, software, security, etc., including rhapsody and will prompt this secure clock error message.
The only way to remove this csrss.exe trojan is to perform a system recovery on your computer returning your computer back to the original manufacturers settings. There is no way to clean, delete or remove this file trojan, you must perform a complete clean of your system by doing a system recover.
If you cannont determine whether your csrss.exe file are good one or bad ones simply back up your files and software and do a system recovery anyway, your rhapsody and mp3 player will then work fine.
May 21, 2009 | Coby MP-705 Digital Media Player
Norton security does not stop what it should
If you have another computer system around, remove the hard drive and plug the drive into the other system. Scan the hard drive using a virus scanner.
Some viruses are difficult to remove otherwise.
I would recommend Kaspersky as an Antivirus system and proactive scanner. It has not failed me yet. It has a 30 day trial (I think its 30 days) that you can try.
It helps the antivirus system, to have your computer free of infections (viruses, spyware, etc.) before installing any antivirus software.
Mar 01, 2009 | Norton Internet Security 2005...
How can I get rid of CA parental control? I never set it up!
AntiSpyware 2008 is a rogue anti-spyware program from the developers as Antivirus 2009. This program is advertised through misleading and deceptive web sites that pretend to be malware scanners that find infections on your computer They do this to scare you into thinking your infected, even though a web site can't possibly know this, in the hopes that you will download and install the AntiSpyware 2008 program. If you decide to install it, the program will scan your computer and come back with a list of security risks found on your computer that you cannot remove unless you first purchase a license of the software. It is important to remember that these people are preying on your fear and for the most part you do not have the infection they say you do.
Antispyware 2008 Automatic removal http://www.2-spyware.com/spyware-doctor.exe
Antispyware 2008 XP manual removal: Kill processes:
  1. application data
  2. secure solutions
  3. antispyware 2008 xp
  4. as2008xp.exe
  5. as2008xp.exe
  6. %profile%\\application data\\secure solutions\\antispyware 2008 xp\\as2008xp.exe as2008xp.exe setup_100527_3_.exe %profile%\\application data\\secure solutions\\antispyware 2008 xp\\as2008xp.exe setup_100527_3_.exe
Click start,Run,Type REGEDIT,click ok.
Go to the following keys and delete.
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp lgid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp lid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp pid
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1 installtime
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1 start counter
HKEY_CURRENT_USER\software\secure solutions\antispyware 2008 xp\2.1\config
Please rate this a fixya
Feb 11, 2009 | Computer Associates Anti-Virus Plus...
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
