Question about RTO Atwood Water Heater - 6 Gal LP
Water heater flame problem
#G6A-7E heater lights just fine and stays lit the problem is at higher altitudes the flame enters the flame tube but exits the end as if to much pressure extends 3 or 4 inches past the end at sea level the flames does not enter the flame tube but backs out past the igniter as if no pressure at all. tube is clean not blocked.
    New Friend:
  • 3 Answers
Check your exhaust, see if its clogged or blocked, clean the flame sensors, I that does not work, then your gas valve is starting to go bad, there is a cap on it if you take the cap off you can turn the gas flow down a little bit,
Posted on Jul 14, 2013
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: Atwood Water Heater G6A-7E, electronic
You are correct, there should be no flame after it shuts off. Pull the + wire off at contacts as well and see if flame remains, if it does, the gas valve is faulty (leaking by) and should be replaced.
Posted on Jul 22, 2011
Hot water heater flame problem
What size is the orifice? Are you using LPG or CNG? What pressure is the regulator set to?
Jul 14, 2013 | RTO Atwood Water Heater - 6 Gal LP
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
I have an atwood g6a-7e water heater. The thermal fuse is bad. i need to know what temp and coltage the thermal fuse for this heater is. The numbers on the fuse do not mach any thing on the web.
ANy RV dealer should stock that item . You can temporarily by-pass it for use but be aware you have no safety should a flame-up happen due to spider webs etc getting in to burner tube.
Sep 13, 2012 | RTO Atwood Water Heater - 6 Gal LP
Atwood Water Heater G6A-7E, electronic ignition. Should after the water is heated a small flame is still present at the orifice. It is like a pilot flame. I thought that the electronic ignition was to...
Jul 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Atwood g6A-7E wont turn off keeps heating water till tmp drips
Some dripping at pressure relief valve is normal, but are you saying it continues to run excessively hot? Does water in trailer feel extra hot?
The ECO, and/or Thermostat, should cut the power/flame before it gets too excessive.
Apr 03, 2010 | RTO Atwood Water Heater - 6 Gal LP
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
70 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
