Melted power cord to extention cord
AC cord melted to extention cord, now I can't separate them
    Top Expert:
  • Computers & ... Master
  • 37,853 Answers
You will have to cut off both bad parts and install new connectors. You might take time to find out what caused the melting
Posted on Jul 14, 2013
Testimonial: "Oh wow I didn't even think of that. Thanks so much your right on point!"
Power from electical outlet to power a travel trailer,AC,MW,LIGHTS 110to 220
all trailers use 120 volts a 30 amp cord 3 pronged is wired a hot a neutral and a ground a 50 amp cord 4 pronged is 2 lines of 120 volts but its not 220 volt it has 2 separate 120 volt hot lines a neutral and a ground you should see a dealer to explain for safety
Jun 30, 2013 | Cruiser RV 2013 Fun Finder X X-214WSD
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
Why is the electrical wire so short
Don't add an extention cord to an extention cord! Buy a 100' 14/4 extension cord and tie the end to the fence so it won't come un plugged.
If the plug keeps popping out of the short cord at the blower,wrap the cord around the handle to prevent disconnection.
Nov 18, 2012 | Ryobi 200mph Leaf Blower & Vacuum Mulcher...
Compresor will not start under pressure
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However it's not adviseable to run without the thermal reset for an extended time. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background, that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit with no extention cord. But, when using an extention cord, I have a 10 guage cord that will carry the load needed to run the EC12. I also have changed to 100% synthetic oil.
Jul 23, 2011 | Hitachi EC12 Portable Electric 2hp Air...
When we started using toro leaf blower this year the extension cord started smoking and the plastic started to melt. Is it the leaf blower or extension cord that's faulty. Both are fairly new.
You must use at least a 12 guage extention cord . Your current cord mostlikely can not handle those amount of amps for long duration of time.
Nov 07, 2010 | Toro Garden
Where do I get a new power cord for the HP 3970 which has been in storage for a while, but I want to begin using it agains, and can't locate the power cord. HP has discontinued this model and nothing on...
The correct part number for just the "brick style" power module (AC Adapter) for an HP Scanjet 3970 is L1970-80003. It is a specific 12V DC 2 Amp module. Today it can be purchased for $18.06 plus shipping from the HP Parts Store. However, if you are looking for just the power cord to your scanner's AC adapter, this brick style power module AC adapter does require a separate standard C13 detachable power cord to the specifications of your area, for instance, in the USA the power cord to connect the scanner to the power module AC adapter is part number 8120-6260, and it is a common power cord for monitors and computers. I learned all this because I had a scanner error message when I tried to use a different power module on the HP Scanjet 3970 when I lost the power cord to the original module. I hope this info helps somebody else, too.
May 24, 2010 | HP ScanJet 3970 Flatbed Scanner
Coleman Mach 3 ac unit tries to start compressor & kicks off
50 foot extention cord not a problem IF it is at least 10 gauge and plugged in to a 20 amp circuit
Your compressor is shutting down for a lack of AC voltage would be my best guess
Jul 27, 2009 | Coleman Mach III Air Conditioner
Need a power cord for a Zenith L20V26C 20.1 in. LCD Television
You can find a replacement power cord for this model from a major Zenith/LG parts distributor at the following link:
Zenith/LG L20V26C Replacement Part Power Cord
Please note the AC Adapter is no longer available from the manufacturer as you can see here.
Jan 29, 2009 | Zenith L20V26C 20.1 in. LCD Television
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Nov 01, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Replacement power cord
Fryers draw high amps.Goto home depot,lowes and buy a 15amp 125 volt plug.Cut the exsisting plug off the cord,strip the cord down 2 inches you will see 3 wires black,white,green, connect the green wire to the green screw on the plug.connect the other 2 wires on either of the remaining spades(it doesnt matter).let me know
Nov 22, 2007 | Bravetti EP4305FS Deep Fryer
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
