Xerox 7655 When trying to Scan to Email, I have two problems. First, it never makes it past the scanning phase. It either errors out immediately due to unknown input size detected, or it just says scanning and never proceeds. I left it for two hours just to see if it would timeout and provide an error message. It didn't Second, I know the SMTP server info needs to be changed but there aren't any SMTP options in the network settings. I logged in as admin and searched all available options, but don't see where to change it.
SOURCE: HP Officejet J3640 All-in-One No Scan Options
When I triy to scan my document, I keep getting no scan options. Please help.
Posted on Dec 04, 2008
SOURCE: Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Posted on Apr 01, 2009
  • 414 Answers
SOURCE: Error message 2,177,0 and 2,7,0
follow the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=10445
also the contact number
Solution: Contact information for Canon Technical Support.
Canon Telephone Support Contact Information. For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Mark
Posted on Apr 12, 2009
luciana44
  • 292 Answers
SOURCE: I have a brand new HP deskjet F4480. It will copy
hi lindakharkov
Do you have an icon on the task bar for HP.
It may be called Digital imaging monitor or Solution Centre.
Right click on the solution Centre and find the Scan button and scan.
If you do not have HP solution Centre, click on the link below, Choose the correct O/S first.Download the Utility and software. and install.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3742086&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Hope this will work for you.
Have a good day
luciana44
Posted on Dec 01, 2009
SOURCE: Scan to email gives server response error.
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Posted on Mar 23, 2010
Xerox WC 7655 host to host usb failure. comunnication error 7655
Try changin the usb connector of the cable that goes from the screen to the rear left of the machine. There are 4 connectors there.
Oct 01, 2014 | Xerox WorkCentre 7665 Copier
Xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
Apr 04, 2013 | Xerox WorkCentre 7665 Copier
Job failed because scan name is invalid
Hi Anonymous / Kenneth,
I assume you must have this problem sorted by now. ( 2012.)
Perhaps there's a firmware up grade you could look into?
Perhaps you must have to check this problem with your Xerox Concessionaire.
Good luck.
May 14, 2012 | Xerox Phaser 3635MFP/X Multifunction...
How do I scan a document with my Centre pro and
You have to scan it usually a twain program. Do a search on twain program. You have to be connected to the scanner with the usb cable.
Nov 09, 2009 | Xerox Office Equipment & Supplies
Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Jan 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Scan to email
Scan to email needs an IP address or the SMTP server name and the port. Now it depends if you use an SMTP server or are you just at home? Normaly the SMTP port is 25. The SMTP server could be the one you use in your email account as well. Something like mail.upc.ie. If you dont have a SMTP server you cant set up scan to email.
Aug 29, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
Jun 05, 2008 | Xerox DocuColor 12 Color Copier
26 people viewed this question
k24674
