Question about Vehicle Parts & Accessories
I have a 2004 f250 4x4 6.0 the ac doesn't blow hard through the vents I have changed out the blower motor and recharged my ac still did not help any suggestions
  • Vehicle Part... Master
  • 14,363 Answers
The evaporator could be blocked.Here's the part.Best to take to Midas.They charge 19.95 to check out.
Posted on Jul 14, 2013
I have a 2011 dodge 3500 the ac sounds like its blows hard but it's not coming out of the vents very hard
check for loose, cracked, or broken vacuum hose lines. If they are all good, it could the blower motor regulator, especially if it works only one setting.
Jul 08, 2014 | 2004 Dodge Ram 2500
The rear heater blows cold air and front does not blow at all. The only place that warm air comes out, is the defroster vents on the dash by the windshield. It actually warms the entire vehicle, but n
i hadsimale problems on my taho the ac wul not blow cold n the back only the heater would blow and the front would not blow i had to chang the front blower motor and the blower motoer relay in the back every thing is on the top of the rt pass wheel hump swap them out there the same parts to see what broke hat stuf is expencive hope this helps
Oct 17, 2012 | 2004 Chevrolet Tahoe
Air doesn't blow out of heater/ac vents
There is a possibility that the fan may have came off The motor shaft/spindle which has to rotate to blow the air to the vents
Oct 16, 2012 | 1995 Honda Accord
Ac fan doesn't blow hard enough 1985 300zx
If very little air comes from the vents, the fan on the blower motor may be damaged, or there may be a restriction in the vents, or a blend door may not be open completely.
Aug 23, 2012 | 1985 Nissan 300ZX
The ac is not blowing air
there is a resister for the blower motor near the motor under the dash behind the glove box the connectors over heat then they loose electrical contacts look at the connector for melting
Jul 12, 2012 | 2004 Cadillac CTS
Blower suddenly quit working
The recharge of your a/c system and this is unrelated, could be a bad blower motor or blower motor resistor, have you checked your blower motor fuse? If fuse good, check voltage at blower motor, sit under dash on passenger side, just below dash, you will be able to see it, will have two wire's going to it, only one will have voltage with switch on, if you have voltage replace it, not that hard of a job to do, shop repair time to remove and replace blower motor is .7 tenths of an hour, hope this was very helpful.
Jul 07, 2010 | 1998 Volkswagen Beetle
Ac/heater works but doesn't blow air at any speed
Yes. It could be your motor. If there is voltage or your hear the motor running then it could be a vent door not working. There is also the switch and a blower motor resistor that you can check. Hope this helps.
May 17, 2010 | 1997 Buick LeSabre
AC blower sounds like it is blowing full speed but there is hardly any air coming out of vents 2004 Dodge Ram Heavy Duty 2500 Diesel
sounds like a door actuator motor that is not working,the dash will have to be removed to repair the problem
Apr 30, 2010 | 2004 Dodge SRT-4
AC fan will not blow
check the vents under the dash, make sure the a/c vent doors are not jammed, check the blower fan underneath the dash too make sure its still operational, check the fuse for the blower motor, then last check your freon level.
Aug 02, 2009 | 2003 Chevrolet TrailBlazer
AC/Heater blower
not hard to replace blower motor, could have something fell into the vents? check first before replacing motor
Nov 22, 2008 | 1998 Chevrolet Blazer
Vehicle Parts & Accessories Logo
137 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
