Question about Panasonic Rx-5090 Vintage Ghetto Blaster
What's the most common reason for an inoperative radio ???
My RX 5090 is great condition inside and out. Everything works fine except the radio. There is no AM/FM output to the speakers, Internally, I cleaned the switches and the tuner pot with silicone spray, but this had no effect. I could find no broken wires or signs that any liquid had leaked inside. Personally, I suspect the AM/FM switch but am not sure. HELP APPRECIATED !
    Top Expert:
  • Panasonic Master
  • 43,095 Answers
Cleaning the switches and "tuner pot" with silicone spray is not going to help performance much
Posted on Jul 14, 2013
2 Suggested Answers
SOURCE: Panasonic RX DT 707/ How do I remove the speaker
Hi there,the grills are incorporated into the cassing ,so you will have to dismantle the unit,which is actually very easy,all you need to do is remove the 8 screws from the back of the unit,then lie it on it's back,and gently but firmley(can take a bit of force) prise the unit in half ,as all thats keeping it together at this stage is the speaker connector plug,located on the inside, right by the earphones socket.Once the unit is appart ,carfully unplug and remove the 4 speakers,I found the best way to clean inside the grills,is to shower them and you can also use a soft nail brush and soap,to get the grime out of the grills.Make sure it's all dry before putting it back together.
Hope this helps
Jack.
Posted on Nov 28, 2009
Changed battery on 2001 olds silhouette and now the instrument panel and radio don't work. Any suggestions?
NEED RADIO UNLOCK CODE TO RESTORE RADIO
IPC INOP. SOUNDS LIKE IP CLUSTER IT'S SELF, COMMON ISSUE
Dec 27, 2013 | 1999 Oldsmobile Silhouette
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Battery was disconnected before I got the 1991 300TE stationwagon. Everything worked beautifully except the radio and the fan/air-conditioning controls. I found the "code" number for the radio and...
Hello! I can not see any reason the AC would quit working after a battery disconnect...Lets start by checking fuses: 7 (16A) and D (16A)...Also, The refrigerant high pressure switch (left front of engine compartment) may be open...Check the Brown/White wire in its plug for a ground when AC is on...
Guru.................Saailer
Jul 03, 2010 | Mercedes-Benz 300-Class Cars & Trucks
Stereo will not work cold weather until car is warmed up
Is the entire radio inoperative or is it just the display. It's common for the display to freeze up in really cold weather because it's a liquid crystal display unit, but the radio should still produce sound and the buttons should work. If not, check wiring and ground points to make sure they're in good condition. Also while rare, it's possible that a loose connector can lose it's connection when very cold because the metal pins inside with shrink just a little, but if they were just barely touching while warm, the connection will break when cold.. I hope this helps and good luck!
Feb 17, 2010 | Car Audio & Video
99 Solara Radio Light not functioning
Check your fuse, sometimes integrated into other electrical parts of the vehicle. Possibly interior light fuse; cigarette lighter fuse; radio fuse?
Feb 03, 2010 | 2004 Toyota Solara
No sound output
hiya
have you checked the thermal fuses inside... they may of blown replacing the fuse may sort this out
Feb 26, 2009 | Audio Players & Recorders
Panasonic Rx-5090 Vintage Ghetto Blaster Logo
63 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
