Question about Frigidaire FAC126P1 wall/window Air Conditioner
I have a Frigidaire FAC127P1A window unit AC I took out the front panel cleaned it and put it back it does not turn on any more. I am sure no wire id disconnected.
    Top Expert:
  • Frigidaire Master
  • 34,255 Answers
If you removd any knobs to clean the front panel, they may not have been reinstalled properly
Posted on Jul 14, 2013
4 Suggested Answers
SOURCE: My Frigidaire AC/Heater unit model
The problem was in the power cord. I didn't have to disconnect the heat after all.
Posted on Apr 27, 2008
  • 45 Answers
SOURCE: frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Posted on Jun 05, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
    Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
    Posted on Aug 06, 2012
    My ac isnt draining water and creating mold in the house on my furniture & clothing
    drill hole in cabinet to let water drain but be careful of wherer u drill. 3/8 bit is big enough
    Jul 23, 2014 | Frigidaire FAC125P1A Window Air...
    Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
    Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
    I have a Frigidaire model number PLHS67EESB9 side by side refrigerator. About 4 months, I has the water dispenser paddle replaced by a trained technician. Recently, the when the freezer door was opened...
    Start by looking at the circuit boards for any sign of cracks or a trace coming off the board. Also, check all the ribbon wires for any signs of a break, corrosion, and so on. As soon as my database comes back online I will look to see if I have a service manual for that unit and any test procedures that you may do. Also, look at the door switch for any shorts or wire breakage. Post back any results to me.
    Regards,
    Richard
    Oct 03, 2011 | Frigidaire FSC23F7D Side by Side...
    Took apart to clean the dust out and put it back together and it will the machine will not turn on.
    Make sure all your service panels are on there correct. Their are switches on the front and back panel that defeat the harness if they are off the unit. More Here
    Dec 11, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    How to remove the front panel holding the air louvers...
    We have a FAC127P1A and if you gently pull the lower cover by holding each side where there is an indentation it will lower so you can get to the filter. Then either replace or wash the filter. We have another model, FAA087P7A1, and we were able to pull the cover down and lift up slightly and remove the cover and wash to remove the collection of dust, etc.
    On this latter model there is a collection of dust, etc. in the area where the cooling is blown into the room that I would like to know how to remove for cleaning. I feel it is unhealthy the way it is now and would like to clean it before removing for the season. I know I could use q-tips or a small piece of cloth to clean but that is pain staking.
    Any help would be appreciated. Thanks.
    Aug 28, 2010 | Frigidaire FAC126P1 wall/window Air...
    Condensation water is not draining properly on Goldstar AC window unit and backing up and dripping on the wood frame and floor below the unit. Is something blocked it just started happening. I am going...
    Yes,remove the ac unit from the window,and clean it out with a water hose out side,remove all debris from inside the unit,and tilt water out of unit.Make sure there is nothing in the way of the drain,and when the unit is put back in the window,make sure it has a very good tilt outward so the water will for sure flow outside,not in.If this was helpful,please rate,thank you.
    Jun 24, 2010 | Goldstar KG6000R Window Air Conditioner
    Frigidaire fac127p1a 12000 btu compressor
    Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
    Blowing water
    Window Air conditioners need to tip back just a bit in the window...if they are flat or tipped front you will have the water problem...
    Here also is a tip that will help you to keep you Air Conditioner running well...
    Window Air Conditioners - Clean them every year
    http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
    heatman101
    May 07, 2010 | Haier hwr10xc6 Air Conditioner
    AC is spitting out water inside. Where are the drain plugs?
    I have the same AC and had this problem. Sludge builds up inside the bottom of the unit from dust and water build up causing it not to drain and the fan spits the water out. Its a fairly simple fix with a philips screw driver and a wet vac. Unplug the AC first. Remove the AC from the window. Remove the screw inside the front panel below the filter screen. Then you can pop the whole front panel off by pulling it with a little pressure. Now you need to remove the 3 screws holding each of the slider panels onto the side of the AC. Then remove the 3 screws on the bottom of the left and bottom of the right side of the AC. Remove the 3 screws holding the bar on top of the AC. Lastly remove the 2 screws on the back of the AC in the bottom Left and Right corners. You can now pull the top cover off. You can now use your wet vac to vacuum out the sludge that is in the bottom of the AC from the right and left side. There's a ground wire that connects from the fan motor to the bottom plate of the AC, be careful not to hit it. I knocked mine off possibly to it having been rusting in the backed up sludge and had to strip the wire and reconnect it.
    Jun 02, 2009 | Heating & Cooling
    Cannot figure out how to put filter (plastic) back in the pump, hose unit...where does it go?
    If your model number is correct, Appliancepartspros.com has an excellent exploded view diagram of your washer that you can use as a reference to help with reassembly. Just type in your model number and reference Section 4 (Motor/Tub). If you have questions, please let me know. I hope this is helpful to you.
    May 12, 2009 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire FAC126P1 wall/window Air Conditioner Logo
    114 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
