Memorex mt2024 bought used w/o remote. Need to reset back to original settings. There is a parental control on a couple of channels and I don't know the password. Here's the BIG ISSUE, though: I have hooked up 3 different DVD players and EACH time get VIDEO/DVD CHANNEL LOCK message. Is there a way to bypass this w/o a remote?
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
To unlock all its locked functions, you must have its original remote control A universal remote control won't go. Try to get its original one. Don't waste more money by buying a universal remote control.
Posted on Jul 14, 2013
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
SOURCE: Reset Parental Control
Good day.
Try to press power up button, channel up and volume minus at the same time. This should resolve your problem.
chris
Posted on Mar 29, 2008
ShadeTek
  • 81 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
SOURCE: RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
Emerson TV don't know size or model #
you need to use original remote to reset parental control
Apr 23, 2008 | Emerson EWC1304 13 in. TV/VCR Combo
How to turn off the parental control on my LG 42 in. HDTV LCD Television?
Look for any option in operation manual. If it is not listed there, there is now way!
Jul 30, 2012 | LG 42LC2D 42 in. LCD HDTV
Apex model PF3225, The TV is Locked (blue screen with red key on the bottom left corner). Don't have original remote...please help
Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
Mar 22, 2012 | Apex Digital PF3225 32" TV
Lost remote need code for universal remote
since most of the disney TVs are manufactured by memorex company ..... from your universal remote control's manual check the codes for memorex brand & try it .... if you don't have manual for your universal remote then from this link http://www.remotecentral.com/features/remotes.htm identify your universal remote & in that check codes for memorex brand & try it .... while searching answer for your question i have found that many people have same problem that is code for universal remote ..... but they never got right answer ......... & also neither same original remote control nor equivalent remote control is available (spare ) ...... so in case if you don't get right code then consider selling of this TV & buying new tv ...........
Oct 28, 2011 | Disney Lightning McQueen TV
We have parental controls on a couple programs and there are no children in this house. Don't know how they got on there- how do we remove those controls. We are in our 70's.
Try to follow this instruction:
1. Press the menu button in your remote control. 2. Press number 4 to open the v-chip parental control 3.Press and hold the volume down and channel up buttons for 5 seconds if the passcode appears. This will reset the passcode 0000 then enter this to access the parental control. Good day and best regards.
Sep 13, 2011 | RCA Televison & Video
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try Remotes.com to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Tv remote needed
The most inexpensive solution, is to buy a universal remote. I own a One-for-All universal remote (model URC-4220) which works with Memorex TVs. I bought it at Walmart for less than 10 dollars.
If you want to pay a little more money, here are a few websites to visit: REMOTES.COM 1-800-REMOTES
MRREMOTECONTROLS.COM 1-800-221-1471
You can find a few more websites by typing in:
MEMOREX TV REMOTES into the Google searchbox.
Hope these suggestions help you out. Please take a moment to rate the info I have provided, but using the rating system below. Thanks.
Jul 11, 2008 | Memorex MT1194 19" TV
Memorex MT2024 programing
THE ONLY SOLUTION IS TO ORDER A REMOTE FROM MEMOREX. I HAVE TRIED FOUR DIFFERENT UNIVERSAL REMOTES AND CONTACTED THE MFGS HELP-LINES WITH ZERO SUCCESS. I FINALLY GOT SOMEONE AT MEMOREX TO ADMIT THAT THEIR REMOTE IS THE ONLY ONE THAT WILL WORK ON THIS (MT2024) SET. "$88.OO".--- WHAT A DEAL FOR A NEW TV! IF YOU BREAK OR LOSE THE REMOTE, THE FRUSTRATION QUICKLY BUILDS AND ADDS UP TO MORE THAN $88.00
Sep 02, 2007 | Memorex MT2206 TV
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
