Question about Hasbro Furreal Friends Butterscotch Pony
I have smores and the lower jaw seems to jus hang their , can that be fixed?
The mouth does not open when singing how do. Fix please help
Keep a long stick across your lower and upper jaw.
Jan 07, 2016 | Toys
How to get into and fix tail doesnt move anymore
Here is a link to instructions for removing the fur from the FurReal Friends Butterscotch Pony. Beyond that, I have no idea how to fix a broken tail. If you can find somebody who works on robotic/animatronic toys, or a good handyman, they can probably fix it for you.
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/?ALLSTEPS
Dec 22, 2011 | Hasbro Fur Real Friends Smores Pony
I've just bought my b&d cordless 14v hammer drill but the instructions were just a few pictures. one of them was of an allum key in the chuck and hammer striking it but i dont want to damage the drill....
Hi. Try the drill at slow speed without any drill bit in the chuck. Look closely to see if the chuck wobbles off centre whilst holding the drill firmly. If it does then there is a good chance that the chuck is loose from the body. If it seems ok then next close the chuck (tighten it closed) to see if all the 3 jaws are lining up ok and open it again to see if the jaws retract back down the chuck smoothly. (jaws are the small parts inside the chuck that grip the drill bit) If the chuck it seems loose then you can use a long allan key to tighten it up which is inside the chuck. If the jaws do not operate properly then i would suggest taking the drill back to b&q for them to fix, or replace the tool as it should still be under warranty. Good luck
Jan 22, 2011 | Black & Decker Drills
Replacement parts for furreal smores pony
I need a carrot and a harnessm movers lost this on me. how do I get a new one or used.
Apr 02, 2010 | Hasbro Fur Real Friends Smores Pony
Hi, ive jus added a pioneer avh5900 in to my car.. the problem i get is when my volume reaches between 17-21 which does seem to blast my speakers, my sounds jus cuts out on the system, altho the system...
Hi does the amp go into protection mode? or does the sound dip and amp stays on? if it goes into protection mode there's a good chance your running the amp wrong. If it dips and stays on its a power problem that can be fixed by adding a farad capacitor.. thank you for using Fixya.com
Feb 09, 2010 | Pioneer AVH-P5000D Car DVD Player
Horses mouth
I had the same problem with mine. There is **** in the upper part of the horses mouth if you gently pull it open a bit and look inside to the jaw area you can see where to reconnect the jaw and pop it back in place. There is also a wire connection near the mouth, so check and make sure this is also connected.
Dec 02, 2008 | Hasbro Fur Real Friends Smores Pony
The ponies mouth
Hi, the pony's jaw is dislocated. There is a **** in the upper part of the mouth that you can look into to see where the jaw fits back in and can be popped back in place. There are also wire connections that may have come undone that can be reconnected easily.
Oct 15, 2008 | Hasbro Fur Real Friends Smores Pony
Hasbro Furreal Friends Butterscotch Pony Logo
42 people viewed this question
Top Hasbro Toys Experts
thegtw
Spidey28
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
