Question about Magellan eXplorist XL GPS Receiver
Magellan explorist XL won't show screen
EXplorist XL when trying to turn on will only show a blue screen then it won't turn off unless you disconnect the power source.
  • 105 Answers
SOURCE: Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Posted on Mar 19, 2008
SOURCE: NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Posted on Jun 26, 2008
SOURCE: My eXplorist XL is locked up
I've had a problem similar to this and found that it was caused by the GPS having trouble reading the SD card, either because it wasn't seated properly or because it was dirty.
Hope this helps
Posted on Nov 05, 2008
SOURCE: Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Posted on Nov 15, 2008
SOURCE: replacement parts for Magellan eXplorist GPS
You need to be brave, but it is pretty simlple. Basically you are going to clean the rubber keypad and circuit board contacts. These contacts develop a film over time that needs to be removed. That is the main reason telephone and remote control keypads fail over time.
1. Remove the battery.
2. Remove 5 screws holding the bady together and separate the backplate from the main body.
3. Now carefully lift the circuit board out of the main body. Do not disconnect anything, but be careful with the rubber seal that fits between the back and front plates.
4. With the circuit board laying flat on your work surface, remove the rubber keypad. It is held in place over the joystick. Carefully lift it off the joystick and set it aside.
5. Use a clean pencil eraser and lightly rub the contacts on the circuit board. Do the same thing on the keypad by pushing the little knobs out where you can rub them. Blow away the dust.
6. Use a Q-tip with some alcohol to clean the contacts on the curcuit board and on the keypad.
7. When the alcohol is dry, put everything back together in the opposite order.
This should be good enough, but if it does not solve the issue, then buy a rubber keypad repair kit (an example is at http://www.mgchemicals.com/downloads/appguide/appguide0206.pdf) and try again.
Good luck.
Posted on Apr 27, 2009
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 | GPS
How can I set up to user grid a Magellan eXplorist GC?
Hello
I've the user manual for Magellan eXplorist. But I can't send it to you by this window, as it does not allow me to upload PDF files by it. If you send your Email address to me by Fixya Comment box, I'll send a copy of it to you by return mail. OK.
Oct 31, 2011 | Magellan eXplorist GC GPS
Need new screen for magellon explorist 100 gps
http://cgi.ebay.com/Magellan-eXplorist-100-200-210-300-400-LCD-Screen-/350437050321?pt=LH_DefaultDomain_0&hash=item5197ad07d1
My recommendation would be simply to replace entire unit unless you have experience fixing electronics.
Mar 03, 2011 | Magellan eXplorist 100 GPS Receiver
When powered up, unit only displays
May have gotten salt water in it and causing shorts, needs to be disassembled, cleaned and dried out carefully..... The corrosion film is almoner invisible and the small surface mount parts can suffer from small amounts.....
Feb 14, 2010 | Magellan eXplorist XL GPS Receiver
No drivers avalible for magellan Explorist 500 for Vista 64 bit
Windows 7 has a windows xp mode that seems to work. I have been using a VMWare image with windows xp for cranky hardware like my explorist xl.
Apr 05, 2009 | Magellan eXplorist 500 GPS Receiver
Screen is out
A black screen, actually purple, means that a firmware upgrade was unsuccessful. You can try to fix it by reloading the firmware, but you are most likely not going to be successful using the USB 'binary'firmware that is available.
There is some 'text' HEX firmware available on the yahoo Explorist user group. To use it though, with your USB cable, you will need to make a small circuit with 1 chip. That site shows how to do it. I am in the process of doing that for an Explorist 400 for a friend. Others have said this is the only to recover such a lost GPS. I'll keep you informed of my success when it happens. I'll probably be sending the circuit/cable I build along to other friends but could possibly fix your for you if you like.
Nov 25, 2008 | Magellan eXplorist 300 GPS Receiver
Jun 06, 2008 | Magellan eXplorist 500 GPS Receiver
LCD screen magellan explorist 210
you are welcome , but send me detailed photo of that lcd
Apr 29, 2008 | Magellan eXplorist 210 GPS Receiver
GPS Logo
32 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
