Question about Car Audio & Video
My 12 VDV/29 Amp "power outlet" is dead as well - no fuses seem to be effected and the radio powers on and seems to function in every other way!
    New Friend:
  • 109 Answers
Check all fuses including under the hood more info would have helped
Posted on Jul 14, 2013
singh_shady
  • 45 Answers
SOURCE: Ihave power but no sound
hi bign,
try the following things:
1:Try checking your ground connections, if they are good, then try regrounding the head unit to some bare metal in the dashboard, you could have a problem with the factory ground.
2:try looking at your speaker connections, sounds you have a wire grounding,try disconnecting all speakers and see if it does it. If not, try connecting one at a time, see if you can single out the speaker thats causing the problem
and also check to make sure the speaker terminals are not touching any metal, which is unlikely, because they are factory speakers.
god luck! and please rate this solution!
Posted on Feb 13, 2009
SOURCE: BLAUPUNKT TRAVELPILOT E1 RADIO/SAT NAV
Posted on Mar 20, 2009
  • 10 Answers
SOURCE: i need to install a 12 volt power outlet on my truck
this should be a simple task for you since the cherokee already runs on a 12 volt power system. the easiest way to do it would be run a single pair wire from the battery itself to a 12 volt connector. there are harder, more detailed versions of this where you would need to dig into the fuse box, but if you are looking to power something low voltage like a gps, cell phone the first way will work.
you can buy the connector and wire with a fuse on it from any autoparts store. you will need to drill through your firewall and I would recommend a uni-bit or multi-bit to get through it. it will go right on to your drill.
Posted on Sep 25, 2009
SOURCE: after dead battery radio has no power
I have same problem and I have no idea how to fix it :(
Posted on Dec 28, 2009
  • 126 Answers
SOURCE: I have a Clarion xmd3 radio that will not power
check to see if you have any grounding issues or if ground is present
Posted on Jun 12, 2010
My radio stopped working after a power surge tripped the breaker for the outlet it was plugged into.
I have had several different makes of clock radios and all said that it was battery back up for power failure
none worked and all settings had to be redone
power surges do not trip breakers as they are in effect a fuse to prevent damage to the wiring in a dead short situation or when a unit fails
even surge protectors will still pass power after a surge but will no longer protect against another surge
Sep 04, 2015 | Emerson CKS3528 SmartSet Desktop Clock...
Need help with a 1998 ford e150 cargo van. Its the base model. No power locks or anything fancy. I have no power to the radio at all. All fuses seem to be okay. Im having an issue finding a fuse diagram....
There is no Relay. But I believe that the Radio chassis has to have good ground. That can be easily checked with a test light connected to a Positive(+) Source.
Nov 09, 2014 | Cars & Trucks
What size inline fuse is in the cobra 29 wt nw
Usually a 3 amp quick acting 3AG fuse---do not use the generic ones from Radio Shack.
If the radio got hooked up backwards look and test for a dead short across the power leads-----there is a diode just inside where the hot lead goes that will be shorted .
SD TECH
Apr 21, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 ltd what is diode d11
if dead remove the diode---check for shorts--also just follow with a volt meter from power source thru inline fuse, up to on/off switch--power ( 12 volts) but not on the other lug with switch on means bad switch.
Apr 06, 2012 | Cobra Radio Communications
Dead receiver/amp.No sound no dial lights. Voltage ok at wall outlet, present at back of amp, but not at auxiliary built-in AC outlet on case of amp. All 4 fuses OK. On/Off switch seem OK. What is the...
the power transformer may have blown the primary winding causing no power for the secondary windings witch means that the main power board has no power
Mar 06, 2011 | Onkyo TX-SR501 Receiver
Can i wire direct to battery to get more power instead of the fuse panel.Plus i have a comet 200 hooked up and only getting 125 watts whats the prob
comet 200? its a 2 pill. 125 watts seems right. The amp should be run straight to the battery always. you can run the radio, but that will not get you more power although it will help with engine noise in your radio. You could be starving the amp if its not run to the battery, but you won't see much more wattage.
Also your dead key will effect your power output. Should have some where around a 2 watt dead key.
This leads me to my next point.
What kind of meter are you using? if its a cheapo pyramid or workman, it may only read average watts. and it will only show you your dead key. It will not show you audio swing. you need a meter that can read peak watts to see your true swing.
you may be doing more then you see on your meter.
Jan 05, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Crate gtx 65 guitar amp mains hum
I had the same problem on my VTX65. I noticed it would oscillate with different effects so I removed the effects module. Problem solved. Now it's dead quiet. I use a Digitech RP500 so removing the effects module was a non issue.
May 19, 2009 | Lexicon LX-7 7-Channel Amplifier
The power outlet under the cup holders
check these fuses:
under the hood fuse panel:
#23 - auxiliary power
#25 - ac/dc inverter
instrument panel fuse panel:
#29 - retained accessory power
if these fuses are good and they have power at the fuse panel, the outlet itself may be bad. if your inclined and you have a test light you can check to see if the outlet has power going to it by probing the wires on the back of the outlet if you can get to them. test the red and white wire for 12v positive and test the black wire for a good ground. if those wires test ok then it its the outlet itself that is bad. if the wires do not test ok then there is a break in a wire somewhere which will have to be traced and repaired
Oct 29, 2008 | 2007 Chevrolet Uplander LS Minivan
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
