Question about Canon EOS 60D 18 Megapixel SLR Digital Camera w/ Tamron 17-50 VC Lens
Search Fixya...60D on/off switch is sticky
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Get some alcohol on a q-tip and swipe around the button see if that get's the sticky off.
Posted on Jul 14, 2013
Flash won't pop up canon 60d
check whether the flash unit is struck, loosen with a film piece, just insert through the groove of the flash unit, this will help to loose the sticky lock from in side.
if the popup relay circuit pbm you must open it check the circuit , the electromagnetic relay an related mechanism. beware of shock hazard from the capacitor.
Mar 07, 2016 | Canon EOS 60D Digital Camera
My canon 60d is blank in the viewfinder all other things are working?
Could be your mirror is in the lockup position. Look on page 125 and 257 of the manual.
Removing the battery, and reinserting it. Then switching on the camera, could also do wonders.
Jul 15, 2014 | Canon EOS 60D Digital Camera
Camara flsh do not open
There is a pin under the spring in the hot shoe (the flat plate). Check to see if it is stuck down. If so the camera thinks there is an external flash installed and will not operate the built in flash.
You can gently pry up the spring and then remove the four screws to take off the hot shoe. Then using a Q-tip dipped in Windex rub it over the pin. Many times it is stuck because of sticky liquid spillage or water damage.
Nov 10, 2013 | Canon EOS 60D Digital Camera
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
Error 05 for 60d hot to fix it
Error 05 is the flash failing to rise. Usual cause is dirt, impact, water damage, or spillage around where it pivots from the top cover at the back. It also may be failing to go all the way up if you are wearing a baseball cap and it hits the brim - thus the flash up switch does not close and the camera goes into error mode
Jan 29, 2012 | Canon EOS 60D Body Only Digital Camera
My new canon eos 60d will not format my new promaster memory card, Message keeps coming back " system busy please wait" did it four times and waited over 30 mins per time
The 60D unlike it's predecessors uses an SD/SDHC card I'm not familiar with the "Promaster" brand of memory card but what all SD cards has is a little lock on the side it's a little white switch that needs to be slide forward to the top of the card to unlock. Once done the card should perform the same way as a Compact Flash card.
If this is not the problem I would suspect a faulty card
Dec 28, 2010 | Canon EOS 60D Digital Camera with 18-200mm...
My Canon 60D's internal flash will not pop up after removing my speedlite 430EX II. Carl
I encountered this same issue on new 60D. There is a micro switch under a guide blade in the shoe on the right side. Mine was not stuck down but bent just enough downward that the switch was being actuated. I used a pointed pocket knife blade to pry up on the guide blade making it arch slightly upward and everything is fine now. Now i wonder is this going to be a problem every time i mount and unmount my external flash. Time will tell.
Dec 17, 2010 | Canon EOS 60D Digital Camera
An English copy of the Canon EOS 60D Manuel: I
You can download the manual and more from
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_60d#BrochuresAndManuals
Oct 11, 2010 | Canon EOS 60D Digital Camera with 18135mm...
Canon EOS 60D 18 Megapixel SLR Digital Camera w/ Tamron 17-50 VC Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
