Question about Acer Computers & Internet
Connecting att uverse
We got at&t u-verse modem/router and when the at&t guy set it up my acer laptop wouldn't connect it just said windows unable to connect to (router name here) and in the network i right clicked on the router but it just said connect it didn't the properties button but i could connect my desktop and ipod no problem i showed it to the guy and he knew what the problem was and in less than 1 min he had it connected and i have never had a problem with it but 8 months later i had to restore my laptop to factory settings and now it wont connect again just like before does anyone know what the guy did to let me connect? Ps i can connect to other routers just not mine
    Top Expert:
  • 12,223 Answers
Go to control panel and use the utility system restore, and put the last date that you know was working good and ready.
God bless you
Posted on Jul 14, 2013
SOURCE: Acer Aspire 5315 with Windows Vista Home Basic will not connect wirelessly to our router but will connect to others.
hi i have just bought a Acer Aspire 5315 on vista i wanted to put it back to factory reset but it seems that they have taken out the back up to do this can i get a disc from any were or any help i would be most greatful thanks dee
Posted on Mar 21, 2008
Mark_Webber
  • 472 Answers
SOURCE: Laptop not picking up Wireless Routers
Firstly check that it is installed by going into Device Manager.
Goto START - SETTINGS - CONTROL PANEL - SYSTEM - DEVICE MANAGER
Look at the list, If you see your card there with a yellow question mark, or a red exclamation mark then it has an issue.
Firstly unistall the device by right clicking it and select Unistall.
Then reboot and Windows will detect the card again and reinstall the drivers for it.
Check back in Device Manager to see if it is still the same. If so, it is possible it is a hardware failure and would need to be replaced.
Beofre you get to that stage though, turn off the laptop, remove the card (it will be underneath under a panel and will have 2 wires connecting to it) then put it back in making sure to push it into the slot correctly. You do not need to remove the wires to do this, and the card does not need to come all the way out.
Post back if you are still having issues.
Posted on Apr 21, 2008
geminii_lady
  • 87 Answers
SOURCE: Need to Change WEP Data Encrytion to WPA in Wireless Network Connection Properties
Hiya, first thing you should check is that your wireless card/usb on your laptop actually supports WPA. I changed to WPA and 3 out of 5 of my laptops could not log on. Took me an age to find out what was wrong. Try changing back to WEP on both units. If they can both log on then see if you can try to borrow a wireless card that you know supports WPA, change back to WPA settings and see if new card works. Don't even assume that new cards/usb's are all WPA compatible. Friends was bought in Nov and isn't able to run WPA.
Posted on Apr 23, 2008
  • 33 Answers
SOURCE: wifi saying limited or no connectivity
Sounds like you have a bad piece of hardware. Can u surf with a hardwire to router? I would consider purchasing a wireless usb adapter and installing it to test with. The winsock repair that you performed would only fix a browser related issue. I doubt that you have mac address filtering enabled on your router, but if you do then that would explain why you cant connect. Then again you would be able to connect to other networks, just not yours. Hope this helps...tennis123
Posted on May 20, 2009
brannfenix
  • 81 Answers
SOURCE: Dell laptop with wireless card unable to connect to network
The specs for the Dell Inspiron 6000 with the Intel PRO/Wireless card are list as 802.11b or 802.11g while the router you bought uses 802.11n.
Your best bet at this point would be to either return the linksys router and get an 802.11g model which is slower than 802.11n, but will be supported by your laptop. Or you can buy a 802.11n wireless adapter for your laptop to connect to your new router. Either way the rules of wireless are you need your device and router to be speaking the same wireless standard. So, pick 802.11n or 802.11g and stick with that standard for your gear.
Posted on Aug 20, 2009
What kind of wifi remote/wireless do I need for a Samsung galaxy tablet?
If you have a combination modem/wireless router you should be able to connect your tablet to the internet. If not, you will need to either buy a wireless router that connects to your modem to broadcast the wireless signal or contact your service provider and get the combination modem/wireless router.
Dec 27, 2014 | Samsung Galaxy Tab 3 Lite SM-T110 8 GB...
Have ATT Uverse & it always drops the internet connection. I reset the main 2wire box weekly. The little router by my desktop is the problem - I have to disconnect & reconnect several times per...
check with 2wire website for a newer firmware version. if you are able to update to a newer version and still have problems, then your router is on its way out.
Aug 24, 2010 | 2wire (1000-400108-001) Router
Att u-verse remote code for coby tftv1923? not
Here, try this link. It's a rather large pdf, so it may take a little while to open.
https://uma.att.com/assets/files/U-verse_Feature_Guide.pdf
Apr 02, 2010 | Coby TFTV1923 19 in. LCD TV
How do I connect a Linksys Wireless-N Model WPC600N to a 3800 HGV-B Gateway modem/wireless router use for ATT U-VERSE service?
hi! u need to setup the wireless settings of your modem/wireless router in order for the wireless network adapter see ur wireless router, check ur wireless settings first. or try to contact ur isp provider who supply the model/wireless router..
Jul 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Internet connection
Hello, Yolie312000 -
I believe you will need to have an AT&T (AT&T Uverse?) technician scheduled to come to your home to check on your WiFi connection.
We have AT&T Uverse for our Internet service provider and experienced WiFi speed slowdown a couple of years ago. We telephoned the AT&T service number, spoke with an AT&T Customer Service Representative for technical issues. He scheduled a repair technician who solved our problems.
You will need your account number and PIN when you speak with the Customer Service Representative.
This is the number to call: 800-288-2020.
Best wishes.
Dec 23, 2017 | Arris Netopia 2240N-VGx Router
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
