Question about Dryers
How is motor wired
What attaches to unground terminal P1 and line t5 and t4 for 230v wiring on a dayton 6K041M motor
  • 4 more comments
  • Steve Money Jul 14, 2013
    Let me clarify my question. I have a Dayton 7 lead dual voltage (115v/230v) motor( model 6K041M)
    It has diagrams on it that indicates low voltage and high voltage connections. Low voltage connections indicate P1(ungrounded) line, P2 ,T8 and T3 connect together and tape, T2,T5 and T4 connect together and connect to line.
    High voltage connection indicates P1 (ungrounded) line, P2 tape (separate), T8, T3 and T2 connect together and tape, T4 and T5 connect together and connect to line.
    Oh there is also a green ground in addition the above mentioned leads.
    The clarification I need is what lines do I connect. I have found conflicting info online. Go figure. For low voltage typically one hot line (115v), one neutral and one ground. I dont think it matters which the hot or neutral is connected to P1 or T2,T4&T5(combined)?
    I would like to wire it for high voltage (230V) P1 line and T4&T5 line, what do I connect to these leads? 115v each or 230v to one or the other?
TheMobilian
  • 8220 Answers
SOURCE: I need a schematic for a Maytag Elec Dryer HDE606
Man I been digging around in the shop for my copy of a DE606 manual I have to no avail. hell I might have even thrown it away.
Well you have a common wire, a start wire,a run wire and 2 larger wires which carry the heater load. go with the 2 larger wires on those terminals for the cent switch. White would be common so that leaves 2 to guess at seems to me those might match number for number. Just guessing cause I ain't worked on one of these halo of heat models in years.
Posted on Jan 13, 2009
kachbibi1
  • 979 Answers
SOURCE: Maytag DE 412 Door switch
Attach the white to the common and the yellow to the NC, which means "normally closed". Normally, the circuit is closed which allows the dryer to run.
Posted on Jan 14, 2009
  • 10865 Answers
SOURCE: Trying to wire for 115v
You probably know that you have a pricey and complex motor there. I can be wired for either 110 or 220 volts and it even has a reverse. I am guessing that new it would cost around $700.
That being said, I want you to consider having it wired by a pro since no wiring diagram is available to you.
If you don't want to hire a pro, then i would contact the Grainger folks and see if they can obtain the wiring diagrams for you. good luck with it.
Posted on Mar 29, 2009
Healeyman
  • 1198 Answers
SOURCE: dryer will not start
Have an electrician look at your hookup. You don't want to damage a new machine.
Posted on Apr 29, 2009
  • 82 Answers
SOURCE: WHIRLPOOL LAUNDRY DRIER.NO HEAT DURING DRYING
sometimes it raps around the pullys or moter pulley it should be a neutral feed
Posted on Jun 29, 2009
Trying to wire a single phase 1HP motor to a standard hot, neutral, ground plug. J10 Black ----] 2 White----] low volt line T4 Yellow---] P2 Brown----] T3 Orange---] T5 Red--------] P1 P
didnt specify to much --generic answer -- sounds like hooking up a heating or cooling unit black and white should be your line voltage use a meter to test your black and white line for 110v if motor is 110v the low voltage lines are control or switch lines that dont go to motor they usually go to a thermostat or transformer
May 04, 2017 | Cars & Trucks
Need to know what wire goes to were..on a smith & jones modle 67841 compresser motor..p1 p2 t2 t3 t4 t5 t8..to what wire black white green
Hey guys, this motor is reversible. I have it wired to turn clockwise(according to diagram),
green to ground;
L1 (black) to P1;
L2 (white) to T2-T4-T8;
P2-T3-T5 together .
When I plug it in, the motor turns counter clockwise and the on/off switch does not work. How do I fix?
Oct 27, 2012 | AO Smith A O Smith Motors Centurion 1.5hp...
115v electrical hookup for dayton motor 1TMY6
Dayton manufacturing is owned by WW Grainger
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1TMY6&op=search&Ntt=1TMY6&N=0&GlobalSearch=true&sst=subset
Contact Grainger 1-800-323-0600
They will have wiring information for each of their products.
The wiring diagram should appear on side of unit.
This 1.5 Hp motor can be wired for 115 or 230 volts
My AO Smith manual would not be specific to your motor.
With AO Smith 115-230V, there are one set of wiring terminals for incoming wires from breaker box. The other wires connect to terminals.
Copy following illustration link:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Wire and breaker size:
For 120Volt, use 20 amp breaker and 12 gauge wire up to 25 feet.
Over 25 feet up to 100 feet, use 30 amp breaker and 10 gauge wire.
100-150 feet use 8 gauge wire and 40 amp breaker.
150-200 feet use 6 gauge wire and 50 Amp breaker.
Sep 28, 2012 | Dayton Permanent Split Capacitor Motor Fan
I am trying to wire a dayton booster pump. it shows a L1 and L2 connection on the 115v connection. L1 goes to P1 L2 goes to T4. on the 220v connection it shows L1 and L2. L1 goes to wire P1 and L2 goes...
The power cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground
Jul 17, 2011 | Kitchen Ranges
I have a dayton 3/4 hp fan motor. I need to change voltage from 230 to 115. Where can I get a wiring diagram showing the wire changes that I need to make. I have done this before but forgot which wires...
There are many different types of motors. you should have a diagram on the inside of the wiring compartment cover. This is a dayton diagram, but I can't be sure it is the same as the motor you have.Notice line terminals remain the same, but that the internal wires change terminals.
Aug 05, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
Hi there, we have replaced dual infinite switch on our jennair range and cannot figure out the correct wiring for the new 12002125 switch....can you help...???
Follow the instructions below from partselect:
Attach the black wire(s) from the old switch (terminal 2) to the new switch terminal P1. Also attach the jumper cable to P1 and "jump" it to S1.
Attach the orange wire (old switch terminal 5) to S2
Attach the yellow wire (old switch terminal 4) to 4a
Attach the tan/(white?) wire (old switch terminal 3) to terminal 4 on the new switch
Attach the single red wire from the right front element to terminal 2 on the new switch.
Attach the 'compound' red wires (the ones that come from the left rear/outlet connection and is also attached to the right rear switch) to terminal P2 on the new switch.
There is no need to separate the compound red wires.
Best regards.
G.
May 28, 2009 | Kitchen Ranges
Mar 29, 2009 | Dayton 1hp 1725RPM 56C Frame 90 Volt Dc...
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
