Question about Home
Hi, I have a cracked toilet cistern lid (brand: Kalevit) . Would I be able to get a new lid from somewhere? Please advise
    Master:
  • 966 Answers
Try manufacturer or local supplier. Failing that try craigslist and kijiji. GOOD LUCK. Or there ae bath fitters and restorers who might be able to renew the lid.
Posted on Jul 30, 2013
  • 2712 Answers
SOURCE: How to Install Toilet
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Posted on Aug 27, 2008
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
  • 5 Answers
SOURCE: Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
Posted on May 18, 2009
bearsfan7538
  • 119 Answers
SOURCE: tank fill valve sticks
Defective fill valve contact Toto for a free replacement part
Posted on Dec 08, 2009
co7196
  • 3433 Answers
SOURCE: cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
Posted on May 26, 2010
Had an opella flush system fitted in January this year, now the cistern doesn't fill up after the toilet is flushed, unless the cold water tap is turned on. Can you advise? Feel I should call the plumber...
The fill system should have a small tube that runts down an open tube in the tank to the cistern. Remove the tank lid and place the tube back in the round tube about 3/4' in diameter and open.
Dec 16, 2014 | Home
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 | Home
How do you get the lid of the cistern?
Dear i_mckie224,
Most toilets you will find that the cistern lid should lift off without the need to remove any screws, nuts or bolts. some on the otherhand, such as the Dudley Elite, sometimes has a screw on the top of the cistern that you need to turn in order to remove the lid, but generically, as said, they should either lift or slide off. If you can provide me with more details about the toilet itself, then I will be able to assist you in finding the answer
Yours sincerely
Oz
Feb 28, 2011 | Toto Home
Hi i have a closed cistern on my toilet and the flush wasnt working! Eventually got lid off after much turmoil and flush works without lid but when lid is fastened on - it flushes but water keeps syphoning...
If water is constantly running into the cistern you will need to change the rubber washer in the shut-off valve. Washer kits are available from most DIY stores. Turn the water off at the isolating stop-****. Unscrew the end of the inlet valve (watch out that any springs etc. don't ping out) change teh washer and reassemble in reverse order.
Feb 17, 2011 | Plumbing
I need a cistern lid for k-11465-0 white, please advise price
You will find it hard to find a tank lid by it's self. You can go through Kohler and get the part and it will run some where around 60 bucks you might get lucking on eBay.
Feb 02, 2011 | Kohler K-11465-0 White Cimarron Comfort...
Cant get the lid off a push button cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Feb 01, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
Replacement button needed
HI, Duravit spare parts can be a nightmare to find, and my best solution to you would be to unscrew the push button from the cistern lid. Take it along to your local plumbers merchant who will more than likely have a suitable non-genuine part that will work just as good.
Jan 14, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
When cistern fills with water it leaks into the bowl
This is caused by the 'syphon' mechanism sticking, quite often nowadays the 'brilliant' plastic push button/ syphon combo sticks, and most toilets are fitted with an internal overflow, lift the lid on the cistern and check for anything causing an obstruction.
More often than not, it's a tiny bit of scale that causes such a headache, and the fact that nothing is made with any quality nowadays!
If you can't see what's wrong call a plumber, he/she will solve it.
I hope this helps
Steve
Jul 09, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Home Logo
152 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
