Question about Whirlpool 8572546 Duet Sport Stacking Kit
My duet sport combo shakes like crazy
I set them up level, but it hasn't helped. what am I missing?
  • 64 Answers
Suspect your load of clothes is incorrect. Wash large & small items together. Large bath towels, or bath / toilet mats and trainers are notorious for becoming out of balance. As is a 'too small' load as well.
Posted on Nov 04, 2013
My line 6 spider mk 11 starts making a cracking noise about 50-60 seconds after i turn it on, then loud fuzz noise- whats wrong plz help
Disable ALL digital settings....problem gone? If not, with tube guards and/or shileds removed try lightly tapping on each tube (one at a time). Does your amp go crazy while tapping one particular tube? If yes then it is new tube time.
Oct 18, 2012 | Line 6 Spider Valve 112 MkII 40 watt 1x12...
I have a duet ht. Whenever I set it to do any wash program, it progresses perfectly until the 1:00 minuet mark. Then it just rocks back an forth forever. If I then switch it to "drain &...
The program must be detecting over sudsing. How much detergent are you using? Are you using HE?
If not then the motor will over amp, heatup, and, lock up. If soap is not the issue then you have objects between the tubs causing the problem. Duet sport service manual
Jul 16, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
My washer shakes like crazy. What should I do about this problem
First you need to make sure that your unit is leveled. The feet are adjustable so that you can level it.
If it still shakes after you level the entire unit, then something in your tub/basket is malfunctioning or come loose. I would suggest you try to move the inner tub by hand to find out it it moves freely and if there seems to be a bad place in its revolution. If there is then you will need to disassemble to find out what the problem is.
Note: There is supposed to be a counterweight installed (http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-GHW9150PW2/1198/0153200/W0607224/00005?blt=06&prst=&shdMod=) Item #9 on this unit. I recently went on a repair call with a similar writeup as yours. The couterweight was attached with one bolt only (should have been two) and that bolt had loosened and the counterweight was not counteracting the drum weight.
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have never been so unhappy with a washer as my Duet front loader. It SMELLS horrible at times, spins and shakes violently. My clothes are always in knots, especially the sheets. My first Whirlpool and...
We had problems with ours shaking but it wasn't completely level.. But I use the clean washer cycle that uses bleach only and it works pretty good. Other than that, I don't have a clue..
Apr 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our sport duet washer shakes violently even thou it is level
Under neith the tub is a series of shock absorbers like on a car, from time to time these come loose or fail. I have a duet repair manual:HERE
Jan 24, 2010 | Washing Machines
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Whirlpool 8572546 Duet Sport Stacking Kit Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
