Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Hdmi error my hdmi isn't working i did the SELF DIAGNOSTIC FUNCTION and it says hdmi no 40705122 err code 81 can some please help
    Champion:
  • 247 Answers
U need a tech to help u the hdmi is corrupted and needs debugging a tech will use a pc set the hdmi
Posted on Jul 18, 2013
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
Hdmi wont work did the SELF DIAGNOSTIC FUNCTION and it says hdmi no 40705122 err code 81
the hdmi is a hdcp circuitry meanining it handles high-bandwith digital content protection hence the hdcp its a security copy device that protects a device from intercepting digital data, this error code means its corrupted and needs to be reprogrammed digitally u will need an computer tech conversant with computer digital electronics
Jul 14, 2013 | Toshiba 57H82 57" Rear Projection...
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
How to reset error code E00000-0010
This is the standard proceedure for the Canon ImageRunner Copiers and all that I'm sure will follow: Press the " Additional Function " key, then press " 2 & 8" at the same time, then the " Addtional Function " key again. You should now see the service mode screen. Press " COPIER ", then " FUNCTION, " then " CLEAR, " then " ERR ", then " OK. " This will clear the code out of the copier's memory. Please be careful in service mode becuase you can do very distructive things in this mode that may take a Canon qualified technician a long time to resolve. Power down the copier at the main power switch, wait a few seconds then turn the copier back on. If the error comes back then you have a fixing assembly problem that will have to be resolved before being able to use the copier. Good Luck.
Sep 13, 2012 | Canon imageRUNNER 5570 Copier
How to reset canon printer ir 2320L
I'm not faliliar with this model as I only work on American sold models but I'm sure the following may help. I'm also assuming you have an error code and turning off and then back on the power didn't help. Try resetting the error code by going into service mode: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. You should be in service mode. If not press the reset key serveral times to make sure everything is reset and try getting into service mode again. Press the " COPIER " button on the display and the screen changes. Press the " FUNCTION " key across the top of the display and then " CLEAR " then " ERR " and finally " OK ." You have cleared the error out of the copiers memory. Turn off the copier waits a few seconds then power back on. Hopefully this gets you in the right direction.
Aug 15, 2012 | Canon imageRUNNER 5000 Copier
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Jan 06, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
My tv model is sony KDL-52VL150 . problem is when i try to turn on after few second it gose standby itsalf's, and also i did unplug from power outlet & put it back & wait, but same thing,...
Hi Mizanur,
First of all, thank you for posting your question here at Fixya.
Your TV has a built in self diagnostic software that can help us diagnose accurately where the fault came from once the unit gone to malfunction. To activate it, press the following buttons on the remote control within a second on each other in standby mode( red LED is on), "Display", "5", "Volume (+)", "Power". Initial screen will be displays as follows :
To display the self diagnostic list, press12_14_2011_11_34_30_pm.jpg on the remote control.
The screen will display the list of error log as follows :
Numerical value "0" means that there's no error detected, "1" means that an error was detected.
Please let me know what error code(s) with numerical value "1" to continue our diagnosis.
Kind Regards,
Jdvillanueva
Dec 14, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
E000002-0000 WHAT DOES THE CODE MEAN?
as you didn't specifed the model, here is general description:
The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
It can be due to faulty fixing heater in models with fixing film, or faulty thermistor's in models with teflon roller.
In most copier's the procedure for clearing is the same.
If it is temporary trouble, you can reset the error:
While copier is showing the error:
1) Press the User Mode key ' * ' .
2) Press '2' and '8' on the keypad at the same time.
3) Press the User Mode key ' * ' on the control panel.
Then choose ( if touch panel ) COPIER, FUNCTION, CLEAR, ERR turn it off and on.
If the model isn't with touch screen instead of pressing on display use the arrows to get to clear press OK and then err and ok, turn off and on.
If the clear doesn't help's call service!
Sep 16, 2011 | Canon Office Equipment & Supplies
Error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Jan 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Got a code c-81 then dvd player won't do anything. Help
A bizarre coincidence but our Sony DVD player DAV C700 did exactly the same when the kids were watching a DVD. All other functions on the system are still working but the DVD player wll not eject or play - and the self diagnosis function C 81 remains illuminated on the display.
Aug 06, 2008 | Sony DAV-C900 System
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
