Question about Android Apps
My key fob will open locks but will not lock doors and trunk. It will beep beep that's it.
    New Friend:
  • 3 Answers
Need to relearn key fob
Posted on Aug 09, 2013
How do i get my fob to work after setting off the alarm?
You should be able to close all doors and use the key to lock & unlock drivers door 2 times each & it should reset all-Good Luck if I didn't see this till too late,JT
Oct 24, 2014 | 1997 Toyota Avalon
Locked the key and fob in trunk and the doors are also locked
break the window out then get it replaced at american glass for a great price. same day service
Jan 08, 2013 | 2006 Toyota Camry SE
2002 buick century key fob problem
Sounds like the remote receiver module in the car is malfunctioning and will probably need to be replaced.
Apr 14, 2017 | 2002 Buick Century
Lexus LS 460 battery dead cant get in car. Doors wont open trunk will open with key. How to get in without key it dont even fit in doors
I work for a doctor and a patient just had this same problem. She had a extra fob in her trunk so we opened the trunk with the key and got her other fob but I am wondering why the key does not fit the lock on the driverside
Feb 13, 2011 | 1992 Lexus Ls 400
1999 porsche 996 replaced key fob battery disconnected battery now trunk releses are locked and cant access battery.How do you open frt trunk manually
Assuming the car battery is ok (if not, buy a male to male cigarette lighter at the auto store and connect to another car until charged enough to unlock the doors...but don't try to crank the ignition!). The trunks won't open if the battery went dead with the alarm set because arming the alarm physically locks the releases.
Sounds like the key code is switched off because you replaced the key fob battery. Try unlocking the car manual with the key in the door lock. Then switch the ignition on to reactive the keyless entry. If this does not work, you might also try pressing the fob unlock button with the key in the door lock until the dash led flashes.
Jun 10, 2010 | 1999 Porsche 911 Carrera
But a used 2006 solara but key fob does not remotely open trunk. Any suggestions?
Yes, insure that you have power to the trunk lock inside trunk, If not could be lose/broken wire or shot fuse. I am sure the key fob does work for the doors? If not have key fob battery replaced. Also, a quick check on power to trunk lock, check to see if have remote power button inside car, if it works power is good. Defective key fob would then be indicated.
Sep 18, 2009 | 2006 Toyota Solara
Keys lock in trunk alarm will not allow trunk switch to lock
The solution is to pull out the back seat to get into the trunk. There are two bolts holding the bottom part of back seat (bolts located between bottom and top sections). Then pull out bottom section of back seat and you see the hinge for the top section, remove the bolts and then you can lift up and access the trunk. It's not that hard.
Jun 08, 2009 | 2008 Hyundai Elantra
Car will not unlock.
To get inside the car .... Use the key in the lock cylinder, unlock the drivers door to get inside. You shouldn't have to reprogram the fob unless it or the keyless module was changed. There may be a blown fuse that supplies the keyless control module (check the owners manual for location). or wires that lead into the Drivers door may be damaged ... The keyless module is located inside the drivers door at the bottom behind the door panel ... do the unlock/lock and trunk release switches on the inside of the drivers door operate the locks and or trunk release? If so it is not the fuse ... and not the wires to it ... And it could be your BCM body control module, located in the dash board to right of your gas petal. Because the number entry keypad (code for that is on the inside of the right passenger trunk bracket arm) also doesn't work I assume it's not the key fobs themselves. Your 98 manual is correct for your car.
Apr 02, 2009 | 1998 Mercury Grand Marquis
1998 Acura 3.5RL lovk button on key fob does not lock the car.
check to make sure all your door are closed, if so check your door switches, one might be bad not allowing your doors to lock
Oct 11, 2008 | 1998 Acura RL
2004 Civic Drivers door lock
The driver's side door lock button is designed not to lock from the inside unless the handle is pulled, or the power switch is used. This serves as a reminder to not lock your keys inside.
If you are inside, and push down on the button (not the switch) hard enough to lock it, you've probably damaged it.
Jun 09, 2008 | 2004 Honda Civic
Android Apps Logo
642 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
