Question about Sport & Outdoor - Others
I replaced my throdel body need to know the idle speed relearn
  • 109 Answers
For one you can't spell and to solve your problem it will relearn it self and when you ask a question unless you have a crystal ball should give some info to what you are working on
Posted on Jul 14, 2013
How to set idle because it it too high
idle is preset uses sensors --try cleaning the throttle body use specific cleaner and same with maf sensor --also look at air filter may need changing -i would suggest the air idle control valve but your complaint is high idle not rough or fluctuating with nissian will need to do relearn when done cleaning throttle body
Idle speed to high
Sep 06, 2016 | 2006 Nissan Micra 1.4
What is idling relearn procedure fo dihatsue mira 2008 car?
Idle Air Control System needs adjusting. The throttle body has the butterfly in the wrong position.
Take it to a specialist!
Jun 21, 2017 | Cars & Trucks
How to fix a dtc p0507?
A vacuum leak Leaking air intake after the throttle body EGR valve leaking vacuum A faulty positive crankcase ventilation (PCV) valve Damaged/failed/dirty throttle body Failed EVAP system Failed IAC (idle air controller) or faulty IAC circuit
Sep 28, 2015 | 2005 Nissan Altima
How do you perform a idle speed relearn
Unhook the battery for at least 30 minutes. Hook it back up and drive away. After so many drive cycles, it will re-learn the new TB. Same process as when you clean your throttle body.
Aug 01, 2015 | 2006 Chevrolet Trailblazer
How do I adjust the throttle body
The throttle bodies on most newer cars are not adjustable for its idle speed. If the Check Engine Light is on, go to the nearest auto parts store and get them to pull the error codes from your car's computer. Post the codes back here and we can give you a better answer to your question
Mar 22, 2015 | 2007 Toyota Corolla
I just changed my throttle body it's a 2005 gmc
Be sure hard idle stop is not holding throttle open if high idle. the ecm on this controls idle
Oct 17, 2014 | 2005 GMC Yukon
Code PO507, CLEANED THROTTLE BODY
you can do a relearn first reset clear mil -code if you can do it with scanner or disconnect battery for a few minutes ----start and let idle for 3 minutes and watch idle should start going down turn off for 60 seconds and let idle again for 3 minutes turn off for 60 seconds and start up and take a drive for about 20 miles need to have speed get up above 44miles per hour for a bit than off gas and let decelerate than back up on speed do this a few times while on drive throttle body should relearn
Apr 19, 2014 | Cars & Trucks
Please help, I have a 2006 nissan altima bought used 56000 miles. Been having stalling issues for a while now at low speeds, making slow turns or just coming to a stop. I have replaced the fusible link,...
sound like you have a distributor that is going bad , the carnk sensor is build into the distributor and sometimes when that gi bad it will cause the car to stall but will not set a code A couple of things here. First, the distributor is probably bad. Second, I would clean the throttle body and check the throttle position sensor. I think the idle air control valve is dirty along with the throttle body so I would clean them first and that should correct the idle thing. The distributor should correct the bucking problem. Now, make sure you have a fresh tuneup like plugs, wires, cap and fuel filter along with a new PCV.
Nov 05, 2011 | 2006 Nissan Altima
Hi i have a code reading P0506 for a 06 GMC Envoy XL any recomondations
{: ) DTC P0506 Idle Speed Low
The usual cause is an excessive carbon build-up on the throttle body. If this is the case, I suggest you have your throttle body cleaned and perform an idle relearn procedure using a GM scan tool. The idle relearn or reset procedure is very important, otherwise this code may still remain even after a throttle body clean.
In a similar fashion, if the ECM/PCM (engine control module) of a high mileage vehicle is replaced and/or reprogrammed without performing the Throttle/Idle Learn procedure, the ECM/PCM may no longer compensate for existing carbon build up in the throttle body, causing it to return with a similar concern as well as DTCs P0121, P0506, and/or P0507.
There are other conditions that can also affect or reduce idle speed by increasing engine load like incorrect torque converter clutch (TCC) operation, accessories that require additional torque to operate, restricted exhaust, and mechanical conditions that limit engine speed.
Aug 02, 2011 | 2006 GMC Envoy
Replaced battery now wont idle
hold revs up for approx 5-10 seconds then slowly bring back to idle if it still stalls have to adjust air bleed screw in throttle body to adjust idle speed
ECU needs to relearn must put in gear then turn on a/c while in gear idling and then turn on head lights then put in neutral while other things are on then turn off all things and go for drive
Jun 27, 2009 | 2002 Mitsubishi Eclipse
Sport & Outdoor - Others Logo
417 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
