Question about Android Apps
I need to change bulb in gear consol - Android Apps
  • 109 Answers
So what are you asking do you have a crystal ball as you didn't say what type of car
Posted on Jul 15, 2013
How do you change a gear shift light bulb in a 1983 Jaguar XJ 6?
the illumination for gear selector is a fibre optic system the bulb located under the centre console
Jan 31, 2017 | Jaguar XJ6 Cars & Trucks
On my ford freestyle gear indicator light how change it
Remove the PRNDL trim ring.
Remove the upper console panel.
Slide the lower shift knob bezel downward.
  1. Remove the bolt and lift up on the shift knob to remove.
Remove the lower shift knob bezel.
Disconnect the light bulb from the PRNDL bezel. an replace .
26002487-w0jffanovav232xjqcbliw5g-1-0.gif Don't think you need take shifter knob off . Just PRNDL trim plate an upper console plate . They should just pull up , use plastic trim tool to get it so you can get your fingers under an pull up carefully .
26002487-w0jffanovav232xjqcbliw5g-1-2.gif PRNDL trim plate
26002487-w0jffanovav232xjqcbliw5g-1-5.gif Light blub connector !
Dec 11, 2015 | 2006 Ford Freestyle
How do u change center console shifter light bulb on a 2000 nissan altima
it's not a light bulb the indicator in the gear console is lit up by a LED that has to be corrected by a dealership mechanic
May 10, 2012 | 2000 Nissan Altima
How to change light bulb on console gear shift indicator. Wife can't tell what gear she is in after dark. Automatic trans. 2004 PT-Cruiser
I have 2002 Cruiser, not sure if it's the same configuration. Here's what I did:
Remove the Console: Slide front seats all the way back and recline them all the way to get the armrests out of the way. Pull the emergency brake ALL the way up. Set the gear shift in neutral. Remove the 4 screws in the cup holders front and rear. Remove the rear window controller (pry out gently), then squeeze the tab and pull out each of the 2 connectors. I also have a 12v socket at the front of the console - squeeze the blue tab and pull gently. The console should be free and should lift straight up with a little coaxing.
Remove the Gear Shift indicator assembly: You MIGHT be able to remove the light bulb without doing this, but I couldn't. With a T10 torx screwdriver, remove the 4 screws in each corner. Lift the assembly up as far as practical (a couple inches). The bulb socket under the PRND21 indicator has 2 very small tabs on each side that no normal-sized human being can squeeze together - I pried the bulb socket out of the white 'shroud' with a screwdriver at each tab location (2).
Pull on the black socket. The socket rotates freely and is NOT the normal "turn a quarter turn and it's out" type socket. (That'd be too easy!) The bulb is a standard interior auto bulb. Replace it and reverse the procedure to reinstall. About 30 minutes for this job.
Nov 01, 2011 | 2004 Chrysler PT Cruiser
2006 pontiac grand prix lights dont light up on gear shift console. How do you change the bulb or can you?
you can, you have to lift up the top of the console and you will see a small bulb, possibly a 194
Sep 16, 2011 | 2006 Pontiac Grand Prix
I have an automatic gear shift console light bulb that needs replacement. It's a 1998 Toyota Corolla. I already removed the two side screws and two compartment bolts to get the two console pieces apart....
That is a very tough bulb to replace. Once you get the center console pieces out of the way there should be a couple of screws or blots that hold down the trim around the gear shift. Remove those and lift gentley. You will barley be able to access the bulb. but it can be done.
Feb 10, 2011 | 1998 Toyota Corolla
Is there a fuse for the lights that light up the gears? And my cig. lighter doesn't work? Is it a fuse that needs to be changed to a blub?
Yes there is a fuse for the cig. ltr. and the lights for the gears. However, a burnt out bulb could cause the gear selector not to light up.
This requires disassembling the console around the gear shifter.
Oct 08, 2010 | 2001 Pontiac Grand Am SE
How to change light bulb in the gear shift of 06 pontiac grand prix
Remove the center console.
There will be a bulb underneath the PRNDL(Park, Reverse, Neutral, Drive, Low) - quarter turn to the left. Pull bulb down; put new bulb in - put back in hole quarter turn to right - reinstall center console...
Jul 16, 2009 | 2006 Pontiac Grand Prix
Gear shift light out in 1997 Honda
remove console and inspect for sought after malfunctioning bulbs and replace and reinstall console .
Nov 30, 2008 | 1997 Honda Accord
Android Apps Logo
392 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
