MCS 160 Boston Subwoofer ZD3 Zener Diode Value
My Boston Subwoofer would not power on. I took the unit apart and found that the Zener Diode located at ZD3 on the power supply board is fried. I'm need to know the value so I can replace it. Any help would be fantastic.
    Genius:
  • Audio Player... Master
  • 1,054 Answers
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Posted on Jul 15, 2013
  • 1 more comment
  • Kawa
    Kawa May 25, 2014
    I replaced the zener diode and still no luck. Going to try the resistor now. Any other suggestions?
  • Chris
    Chris Jun 05, 2015
    Would the resistor make the unit not have sound? I replaced the diode and I got the power back but still have no sound coming from it.
  • Steve K Jun 08, 2015
    yes. if the resistor is bad, then I believe the light will stay red instead of going green and you will not have any sound
How do you repair blown Boston Acoustics Subwoofer MCS Amp?
Most often this unit goes dead because of zener diode ZD3 shorting. It is a 18v zener. replace this and you should be back in business.
Feb 20, 2017 | Boston Acoustics Audio Players & Recorders
Sub woofer not turning on
Is it receiving power? If not that is your answer - could be a blown fuse, bad wire, bad connection, etc.
If power is there and it still does not work then the problem coud be with a bad sub woofer on/off switch, internal fuse, or worse, blown amp from over driving.
Feb 25, 2016 | Boston Acoustics MCS 90 Horizon Series...
My subwoofer had no sound or power. I replaced the ZN3 diode and now I have power but still no sound. Any suggestions?
If this is a boston acoustics sub, then I assume you replaced ZD3. You also need to check R9 on the back of the board. It is a surface mount resistor and should read 10 ohms. This resistor sometimes goes open when the diode shorts.
Jun 05, 2015 | Audio Players & Recorders
Boston acoustics subwoofer won't turn on
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
Jul 03, 2014 | Boston Acoustics Audio Players & Recorders
Hi i have the Boston acoustics soundware xs 5.1 the sub stopped working the led shines red on stand bye and turns to green when the amp is switched on so i have taken it apart and found ZD3 has blown but...
ZD stands for zener diode and used for exact voltage regulation. Take out a known good one and go to a repair shop to replace. Make sure that when you re install, the striped (polarity) markings are in the same direction!
Mar 14, 2014 | Boston Acoustics SoundWare XS 5.1 Speaker...
My Boston Acustic subwoofer connected to my Denon Avr 1312 is not turning on the les light on back of subwoofer dobt even come on had fuse checked but its not blown.
There is a common problem with a zener diode in that amp that goes bad. ZD3 is a 18v zener and it goes short. Sometimes R9 on the back will open when this happens. Need to have them replaced.
Oct 09, 2013 | Denon AVR 1312
I also have a fried zd3 on my boston acoustic mcs 95 Sub amp board. Do you know the radio Shack part number you used and did your amp power up? My Sub is not working. No power and no green light but my...
zd3 is a zenna diode, you will need to find the volts that it triggers at, most amps (99%) have a mirror circuit board so all components are dobbled so this will help you find what you need Re: Jeff
Nov 25, 2012 | Radio Communications
Mcs 160 subwoofer no power
I had the same problem with my subwoofer unit. I found the zener diode ZD3 was fried. The pic below shows the diode and its clearly tagged ZD3. You need a multimeter to check this before you order anything. This diode should only transmit power in one direction. Its size and spec is 18v .5w zener diode. (that's 1/2 w) It's very inexpensive and the whole repair took about an hour. This is from a Boston Acoustics subwoofer MCS 160
Ok..the procedure is easy.
1) unplug the unit and bring it to a well lit work area.
2) remove the panel from the back and locate the board that is held to the panel by 4 screws and has the ZD3 diode. The pic below shows the diode at the end of my test lead. Note the direction of this part and reinstall the new one in the same direction. Its a simple de-solder and re-solder project. I elevated the new diode about 1/8 " from the board with a small strip of copper. This acted as a heat sink during the soldering and elevated the part above the board to help it dissipate heat later when in use.
3) re-install the board and plug in all the connections.
4) this worked for me and I'm enjoying my sound system again!..good luck0482b949-8492-43a6-91df-0fb2f0e6888b.jpg
Jul 24, 2012 | Denon Audio Players & Recorders
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Hello
I need it too.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
No power to display
this response is for folks having issue were the unit is dead no power to display. i have the same unit and it passed on this week.
i took it apart and found the ckt board and the zener diode at location d9 was burnt so was the board.
i replaced that diode with 1 from radio shack it was a zener diode 12 volt. cost 1.39 for 2 now its brewing again.
Apr 29, 2008 | DeLonghi DCM485 Coffee Maker
1,372 people viewed this question
 Grubhead
Grubhead
