Question about Nokia Mirafone OP201 Phone
Nokia 6020- check multimedia settings problem
My Nokia 6020 mobile phone is stuck. It's throwing a message "check multimedia settings" followed by "OK". When I click on "OK", again showing a message "Multimedia message sending failed". Then it is coming back to "check multimedia settings". It's gone to infinite loop. Due to this I am not able to do anything in my mobile. Please do the needful at the earliest.
  • 4 more comments
  • Anonymous Nov 14, 2007
    My Nokia 6020 mobile phone is stuck. It's throwing a message "check multimedia settings" followed by "OK". When I click on "OK", again showing a message "Multimedia message sending failed". then it does not send the mms
  • marhyan666 May 20, 2008
    when im sending my mms
    ..it's said multimedia message sending failed
  • eekeek Jun 07, 2008
    i already change the settings but still sending multimedia failed..why?
  • Anonymous Sep 03, 2008
    I have the exact problem....any fixes
  • kedura Sep 07, 2008
  • buttmuncha May 11, 2010
    "ok , i see that u must download a new software to this mobile"???
    That's a solution??? 91% of people said that was a solution???? That's not even a ******* sentence... What software??? How do you do this when you are in an infinent loop and can't use your mobile???
    Problem Solver:
  • 7 Answers
Ok , i see that u must download a new software to this mobile
Posted on Sep 01, 2007
Yes i have agree i want help
Posted on Nov 07, 2008
    New Friend:
My nokia mobile was working fine but now displays insert correct sim card, cant get past that at all or get into the menu
Posted on Aug 08, 2010
SOURCE:
Restriction code for Nokia 6020
Note : Please try unlocking your Nokia 6020 mobile phone only once using the steps given below with the Nokia 6020 unlock code you get from our unlocking tool. If it does not work, do not try again as it may get your Nokia 6020 permanently locked. Do not enter any wrong unlock codes on your Nokia 6020 mobile phone. If you enter over a certain amount of wrong unlock codes on your mobile phone, your Nokia 6020 phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 6020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6020.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6020 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6020 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6020
Mar 16, 2014 | Nokia Handsfree For 6020, 6101, 6102...
Phone restricted code for nokia 6020
For the best unlock code for your Nokia model mobile,
you can try this site http://www.theunlockarena.com/nokia-6020/rs13wp9/
It provides the step by step instructions and easy methods for unlocking your Nokia mobile phones...........
Aug 23, 2010 | Nokia 6020 Cellular Phone
Connect mobile phone to pc
for accesing net in pc via mobile .... activate ur gprs settings in ur mobile.... now get a nokia pc suite cd and install the necessary drivers and connect the mobile to the pc ...... the console page will have the connect to internet option , please click on that for using internet. if u don't have the nokia pc suite cd download it from net.while installing the drivers please mention ur phone type as nokia 6020.
Feb 26, 2009 | Nokia 6020 Cellular Phone
Need a master reset code for a nokia 6020
the master reset on my phone is either..0000...or.....12345 try these if it fails let me no ill do some research for ya
charlygal
Nov 17, 2008 | Nokia 6020 Cellular Phone
Open the menu then go to setting. Then scroll down go to restore factory setting and open it then enter the security code 12345 if you dont have change its security code. But if you change it the type your own code. Thank you.
Nov 07, 2008 | Nokia 6020 Cellular Phone
Hi pells help me
1)Delete all MMS settings (Menu>Settings>Config. settings>Default config settings)then restore ur phone and get new settings from ur service provider 2)Check start up settings of ur phone 3)Virus Problem(alternate) Thank u Gizmo1
Sep 21, 2007 | Nokia Mirafone OP201 Phone
MMS Problem
RIGHT THAT MEANS THAT YOUR MESSAGE CENTERE NUMBER IS WRONG AND THATS WHY IT KEEPS COMEING UP WITH THAT MESSAGE AGAIN AND AGAIN WHAT YOU NEED TO DO IS IF YOU HAVE THAT MESSAGE CENTER NUMBER GO INO TXT MESSAGE SETTINGS AND CENTER NUMBER AND PUT THE RIGHT ONE IN. ALSO IF YOU HAVENT RING UP YOUR PHONE PROVIDER AND ASK FOR EITHER THEM TO SEND THE RIGHT SETTINGS OR THERE GUIDE YOU THRO AND GIVE YOU THE NUMBER YOU NEED TO PUNCH IN TO GET THIS TO WORK. HOPE THIS HELPS MRS RAVERBABY
Feb 22, 2007 | Nokia Mirafone OP201 Phone
Stucke while sending MMS
At first, Try delete some bookmarks and unwanted stuff from your phone memory (I mean, free-up some phone memory) and try. If it do not work then, You should reset your mobile to factory settings first, then reset your MMS settings asper your operators instruction.
Aug 30, 2006 | Nokia Mirafone OP201 Phone
Nokia Mirafone OP201 Phone Logo
776 people viewed this question
Top Nokia Lands Phones Experts
Piyush Lal
Piyush Lal
ASHRAF CA
ASHRAF CA
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
