Coleman evcon leaking condensate
5 Suggested Answers
  • 142 Answers
SOURCE: My coleman evcon AC is leaking water.
make sure the condensate drains are clean. This will permit the water to drain out and not leak out of the unit.
Posted on Jun 03, 2009
  • 233 Answers
SOURCE: Need a replacement coil for a Coleman Evcon air
This may be a bigger issue than you want to tackle alone, generally speaking the coil will have to be ordered from a dealer, as most wholesalers will not sell to the general public. Further, this will require brazing the new coil in, evacuating the system, installing a dryer and recharging.
Posted on Jul 12, 2009
SOURCE: water leaking from coil pan that is cracked down center
maybe you can fill the pan a little with some type of sealent, like resin, that might seal the crack pan..
Posted on Jul 15, 2009
shastalaker7
  • 1515 Answers
SOURCE: The weld inside the condenser broke and lost
Hi, all I can say it had to be a poor weld from the factory to fail like that. If the weld joint is easy to get to, you shouldn't have to replace the condenser coil. You will need oxy/act. torches and sil-phos or silver solder with at least 15% in it. If you can do this yourself, you will need the torch, a vac pump, and the skills to braze, to evacuate the system for around 45 minutes, and the gauges to charge it. If its a new unit with the new R-410a, you will need the gauges for that freon due to the high pressures. If its the R-22, you need just the regular type. If the joint is right at the condenser coil, you can remove some of the fins in that area to give you more room. It might appear to be aluminum, but its copper to copper and you should have no problems welding it. Do not use JB weld or any type of epoxy as you are wasting time and money, it will not hold!! This is high pressure in the condenser, and no patch other then a braze will hold. If you heat the area where it came apart, use channel locks to push the copper together. You may need to put a 1/2" coupling over the joint. If you feel you cant get excess to the equipment to do this, you will have to call out someone that has the equipment. If you are able to do this, great. The data plate will tell you the amount of freon to put in. I would weigh the charge in after I made sure the unit holds a vac. If it doesn't, its still leaking. Keep me posted on this and I will help as much as I can from here.
Best of Luck,
Shastalaker7
Posted on May 24, 2010
I have a Coleman evcon gas furnace. The inducer motors activates when the thermostat is engaged,but shuts off before the heater kicks on. There is also a blinking red light.
Hello, it sounds like the pressure switch is not closing on your furnace and remaining open, reasons for this could be a blocked flue pipe, the tubing going from the inducer motor to pressure switch could be blocked, loose, or have condensation in it, or the switch itself is bad. U can check the tubing by taking it off blowing some air through it and making sure no condensation is in the tubing, then reinstall it. If everything checks out good then the pressure switch is bad and must be replaced.
Feb 20, 2011 | Coleman Heating & Cooling
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
Need a replacement coil for a Coleman Evcon air handler Model # AH12L10NA. I am losing freon at a rapid pace. Leak detector indicated leaks in the indoor coil in the air handler. PLEASE HELP! Thanks in...
Jul 12, 2009 | Coleman Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Jun 03, 2009 | Heating & Cooling
Evcon coleman furnace
I have a Evcon mod.# DGAH077BBSB with 4 light flash code
Jan 23, 2009 | Tools & Hardware - Others
I have a coleman/evcon heat pump. When the thermostat kicks on the contacts kick in and hum but the compressor nor the fan run. Is this probably my capacitor has gone bad?
I would check the hig voltage power supply to the unit. Check the main breaker and make sure it is on. Check the disconnect and make sure there is power at that point to the condensing unit. The contactor will kick in from the low voltage in the control circuit.
Jul 11, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
