Question about HP Media Center m7250n (ED842AA) PC Desktop
No power when turned on - light green on back - no lights on motherboard - no fans
The computer had been turned off went to turn on no power- green light on back stays on- unplugged/plugged in after pushing and holding in on button - and after waiting 30 minutes - reseated the power switch from mb - still nothing - and tried different receptacle plug that is know to work - it was plug into power strip.
    Brigadier General:
  • HP Master
  • 3,400 Answers
Sunny,try with a other powersupply if possible.
faulty PSU are often the cause.
Posted on Jul 13, 2013
Testimonial: "I had to order one when it comes I will let you know if it fixed the problem - thank you for your help!"
joecoolvette
  • 5660 Answers
SOURCE: Blue button flashes and green light in the back
Power Supply failure. Weak Voltage power rail.
Blue light in the front is the Power On LED light. Green light in the back is on the Power Supply.
Primer:
When a Power Supply is plugged into power, there is a 5 Volt Standby power present in the Power Supply.
When you press the Power On button, this in turn presses against a Power On switch.
The Power On switch is located inside the plastic Power On button.
This is a basic example of a Power On switch,
http://www.directron.com/atxswitch.html
Pressing the Power On switch closes a circuit for the 5 Volt Standby power.
The 5 Volt Standby power is then directed to a circuit inside the Power Supply.
This action turns the Power Supply on.
Power then goes from the Power Supply to the motherboard.
The first chip to receive power is the BIOS chip.
[Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
BIOS = Basic Input/Output System ]
The BIOS chip has the BIOS program burned into it.
BIOS, (The BIOS program), looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the operating system.
(Windows XP is one example of an O/S. Operating System)
Secondly,
1) ALL of the LED lights, use less than 1 Watt of power from the Power Supply.
[ The HP Pavilion a1250n desktop computer, comes with an ATX style of Power Supply, which has a reported Maximum Wattage rating of 300 Watts]
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
[The HP Pavilion a1250n comes an AMD Athlon 64 X2 3800+
This particular Processor uses (Fits into), a Socket 939 processor socket.
The Athlon 64 X2 3800+ can use up to 89 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#Athlon_64_X2
Look under TDP.
This is what a Socket 939 processor socket looks like,
http://en.wikipedia.org/wiki/Socket_939 ]
You have enough power to light those simpy LED lights, and spin the fans a few times, but not enough power to Turn the Processor on, and keep it on.
No Processor running, No computer.
What causes Power Supply failure?
1) Computer is dirty inside, as well as inside the Power Supply.
In reference to the Power Supply;
The Power Supply used in your computer is an SMPS.
Switched-Mode Power Supply.
http://en.wikipedia.org/wiki/Smps
There are two cooling components,
A) The Fan
B) Heatsink's which are used internally. (Inside)
[Typical construction of a Heatsink is a plate of metal with tall, thin fins protruding from it.
The plate of metal absorbs heat, from whatever object it is placed against.
The tall, thin fins absorb the heat from the plate of metal, and radiate the heat away.
If a fan is used in conjunction with a Heatsink, the air flow from the fan goes in-between the fins, and around the fins, and help to dissipate, (Carry away), the heat ]
When the Fan's blades, center hub, and surrounding cage (Shroud) are clogged with 'Gunk', the Power Supply heats up.
Heat = Wasted Energy
The more heat, the more the Power Supply strains to keep up with the call for power.
Eventually components inside the Power Supply fail, and the Power Supply fails.
2) Low quality Power Supply.
Low quality components are used in the Power Supply
The ATX style of Power Supply is used in a Large percentage of computers out there.
Very readily available.
I would suggest you install a Power Supply with more Wattage.
A computer only uses the power it needs, and NO more.
Won't hurt your computer.
Will help your computer as there will be less strain on the Power Supply.
Also the 300 Watt rating on that Power Supply is bunk.
Padded rating to make the Power Supply look better than it is.
The actual Wattage rating, is more like 60 to 70 percent of what is stated.
(180 Watts to 210 Watts)
Need help in opening your computer case, and replacing the Power Supply, and/or a recommendation for a Power Supply, let me know in a Comment.
[BE SURE to follow Anti-Static Precautions, BEFORE you reach inside your unplugged from power, computer ]
Posted on Jul 06, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: My hp a500n will not turn on
Check your BIOS battery make sure it is working correctly and that it is not out. You can use a battery tester to see.
Posted on Feb 14, 2009
  • 11 Answers
SOURCE: wont start power supply binks
What do u mean u unplug the motherboard...?
Posted on May 27, 2009
lglalight
SOURCE: computer wont turn on
i had the same problem its going to be your power supply it probably burned out. when i changed mine it worked perfectly.
Posted on Jun 01, 2009
  • 169 Answers
SOURCE: Power Issue on my HP m7470n
try this link.....it has the steps you need to follow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01732674&cc=us&lc=en&dlc=en
Posted on Jun 24, 2009
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the...
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Oct 20, 2013 | Intel Motherboard
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
No power to computer, flashing green light by power cord
reset the surge protector first!
then investigate the power supply
Mar 27, 2012 | Compaq Computers & Internet
I had a power outage and my computer when I tried to turn it back on after the power was turned back on. All it does is have a green light blink on the back of the tower and a small green light on the...
most likely the surge fried one of your ram chips... this is where i would start first sometimes the ram will work as a surge protection for your motherboard
Nov 18, 2010 | Computers & Internet
Motherboard won't boot: no noise, no nothing...
Shorting the two leads will work but don't keep the two wires together. They are not ment to stay connected. Consider replacing your cases ATX power switch. Take a look at the link provided for a new switch;
http://www.cables4computer.com/Cases_and_Enclosures/Mid-Tower_PC-Cases_ATX_Push_Button_Power_Switch.html
The green LED on the motherboard means the board is in "Stand by mode". This green LED uses 5V DC to light the LED. After replacing your PS back into your system it may function just fine.
Good luck.
Mike
Dec 03, 2009 | Intel Motherboard
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Flashing Green Light on Power BESTEC Power Supply
This is an easy fix so here you go nice and simple:
Problem: Your motherboard circuit has been cut.
Causes: Power disconnected during operation. Power outage or short in the surge protector.
Symptoms: Flashing green light on both motherboard and power supply. System will not power on.
Solution:
Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off.
Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection.
Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now.
Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid.
Step 5: Power on your PC. The problem should not persist.
Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine.
I hope this helped! Good luck!
Jun 23, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
HP Media Center m7250n (ED842AA) PC Desktop Logo
147 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
