Question about KitchenAid Dishwashers
Fix cover latch to KUDS301-VBL
Do I need to remove the inside door to my KUNDS301-VBL, to change out the automatic soap dispenser? Its cover latch does not work. I need to reinstall a new latch cover.
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Posted on Dec 28, 2007
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
SOURCE: Dishsoap stays in soap dispenser
We had problems with soap remaining in the dispenser and dishes not getting clean when we used gel dish doap. We changed to the cakes of soap with a Jet Dry Power Ball in the middle, and now they clean fine.
Posted on Apr 14, 2008
  • 105 Answers
SOURCE: I am trying to replace the soap dispenser on my
As I look at the pictoral, it seems there are twelve screws that hold the inner door to the outer door. Youmust remove these and then separate the door parts. Then you will see the screws that hold the dispenser in place from inside the door.
Posted on Apr 17, 2009
SOURCE: Dishwasher soap dispenser sticks
Your soap is clotting because there isn't enough water being sprayed around inside.  The water spray washes the soap out of the dish, if all is working well.  My machine had the same problem.  I had sufficient water level, but the spray head wasn't spinning very well.  I found the end-most hole in the spray bar to be plugged.  It is the end hole that provides a jet that makes the head spin.  I cleaned a bunch of debris out of the hole and the mchine started working and cleaning like it was new.  That was quite an axccomplishment since the machine is 15 years old.
Posted on Jun 07, 2009
MY SOAP DOOR WONT STAY CLOSED
Soap dispenser latch problem.
a) Look at the latch whether there is build up of soap. CAREFULLY clean it. It might work.
b) If not just replace the whole dispenser unit. Not worth wasting time on trying to fix the spring problem. Most dispensers are $ 50 ~ $ 100 price range.
Sep 26, 2014 | Dishwashers
Vent cover removal kuds301 vbl3
Jan 13, 2013 | Kenmore 17252 Free-standing Dishwasher
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a leak coming from bottem of door only on rinse cycle
If this is a MayTag check the seal around the soap dispenser latch. That seal may have a small crack. You can also take the inside cover of the door off. Then you can see the water marks to see where it is coming from. Mine was the soap latch seal. Cheap fix
Sep 08, 2010 | Dishwashers
Soap dispenser door pops open
Try cleaning the compartment. If the latching is not OK, it could be a latch problem, or alignment, or total dispenser. Contact service provider for assistance.
May 26, 2010 | Maytag MDC4650AW Built-in Dishwasher
Soap dispenser cover will not open when in wash mode
First be sure nothing is blocking the dispenser from opening like the rack broken or an attachment to the rack out of place. If this is all good then clean good around the latch for the door, make sure soap or anything else is not causing it to stick. If all this is good you will need to replace the dispenser.
The part number for the dispenser is 9744543.
To replace it you will need to turn the power off and open the door of the dishwasher, remove all the screws that are on the inner liner on top and the 2 sides. This will allow the the inner door panel to separate from the outer door panel. You should be able to see the screws on the back side of the dispenser from there, 6 total. If the coil (the piece the wires hook to) is melted then I would suggest replacing the control board in the console at the same time as the dispenser, this would be a very rare occurrence but if it is melted it could have caused damage to the control.
Let me know if this helps
Apr 25, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Soap dispenser will not close stays open will not latch
Turn off power to the machine. Remove the inner door panel and inspect the dispenser cover latch for any broken components. If everything looks ok, check the action of the release solenoid by hand. If it is sticky or stuck closed, try removing the center pole piece and clean the solenoid interior and pole piece with a small rag or 'Q tips' with WD40. Don't otherwise lubricate the solenoid. Push the cover closed and push the solenoid pole to release the latch, then repeat the process again. If the cover will latch again, you can replace everything and try a load of dishes. Hope this helps
Mar 29, 2010 | Bosch Dishwashers
Soap dispenser door doesn't open for the second cycle.
Hi, the soap dispenser has a motor / solenoid which controls the latch that opens the door. This has gone bad and needs to be replaced. It is located inside the dishwasher door panel. Remove the screws around the inside of the door to gain access to the solenoid. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Door latch assembly for maytag neptune MAH5500BWW
The plastic cord is for opening the door if the door latch fails. It should connect to the door latch mechanism and the other end should be routed to the soap dispenser corner. There should be two holes for the cord to go into and out again. The idea is to remove the soap dispenser lid / bezel to get access to the pull cord if needed.
Hear the new Neptune bearing song at http://www.neptunehelp.com.
May 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Soap dispenser door not catching properly
THE INNER DOOR PANEL HAS TO BE DISASSEMBLED TO ACESS THE SOAP MECHANISM NO IT DOESNT JUST PULL OUT
Jan 16, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
