Question about Welding Tools
Millermatic 35 parts list
I have a millermatic 35 when I pull trigger gas comes out for a second than stops can you help
  • 71 Answers
SOURCE: No constant gas flow...
a hole in your gas line or the solenoid is sticking
Posted on Aug 08, 2009
luxur4
  • 92 Answers
SOURCE: mig 195 TE gas comes through when trigger operated
you may have a sticking solinoid valve or you are using far too much gas which is holding the valve closed. reduce the gas flow to 12-15 lpm.also check the potentiometer for the gas flow.
Posted on Oct 09, 2009
  • 81 Answers
SOURCE: on my millermatic 185 i pull the trigger and the
Is the ground clamp connected to the work piece?
if so, go through the trouble shooting section of the manual. If you don't have the manual, you can find info at millerwelds.com.
Posted on Apr 21, 2010
witmoz
  • 390 Answers
SOURCE: I have a miller 251 millermatic welder that has no
check the wireing from the gun to the servo,it may have got damaged.then test the servo
Posted on Sep 02, 2010
  • 1212 Answers
SOURCE: when pull trigger the gas solenoid clicks and gas comes out but wont shut gas off when not holding trigger
It is possible the gas solenoid valve is dirty- it obviously opens, so something is abstructing it from closing. This is assuming the usual "momentum" of the gas is not being mistaken for a fault. If it does not shut off after 3 seconds, (and you can watch the flow meter ball drop at the same time), the gas solenoid valve should be replaced.
Posted on Mar 30, 2012
My trigger to my millermatic 250 won't stop feeding the wire even when switch is not pressed
Does it feed with the trigger plug removed from the machine? If so, then it is a circuit board. If no, then wires shorted somewhere in the gun.
Apr 17, 2012 | Miller Welding Tools
I have an echo p250 that just stopped running in the middle of use. I've taken it apart up to but not pulling the head off. Cleaned and rebuilt it. has spark has gas sometimes if I keep the trigger...
I have echo p403. Similar but not exactly my issue. Rebuild the carb if you didn't already. Alternatively, you can buy a new carb approx 35$. After parts purchase and your time, 35$ isn't to expensive. The carb uses a diaphragm that seems to melts over time and use. I'm not a chemist, I can only tell you what I found inside, the diaphragm was like jelly after 10+ years of use.
Nov 01, 2017 | Garden
I have a miller 251 millermatic welder that has no response to the gas being tiggered when i press the gun trigger
Sep 01, 2010 | Miller Welding Tools
Have a miller Millermatic 130XP drive roll not working
Have a 130 xp welds the same with or with out the gas welds not smooth
Jun 29, 2010 | Miller Welding Tools
On my millermatic 185 i pull the trigger and the wire comes out it does not arc against the ground, i tried it against the actual ground clamp, but it still doesnt arc
Mar 29, 2010 | Welding Tools
The millermatic 135 gun has stopped working. Could this be from the switch going out?
If the switch is dead, the gun will not work. Pulling the trigger tells the machine to initiate delivery of the wire, gas and current. If the switch is dead, none of that will happen.
Feb 09, 2010 | Miller Welding Tools
Miller 130XP won't feed wire
need a replacement wire feed motor for a millermatic 130xp
Dec 28, 2009 | Miller Welding Tools
Jul 30, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Millermatic 200 won't weld
first check on the plate that tells imfo of unit ,there is what is called duty cycle.If the duty cycle says per say 30%,that means you can weld full power for 3 minuets before unit will shut down to cool.if it says 100% duty cycle there is no limit on weld time.this is the first thing to understand,if that is not the case check the main contactor where the power imput wires go,pull the gun trigger see if the contactor is pulling in , it should if not no welding amperage.
Jul 11, 2009 | Miller Welding Tools
Welding Tools Logo
181 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
