Hp media center pc m8417c no power green light in back stays on
Also no fans come on no light on motherboard (read that from another article)
    Brigadier General:
  • 3,400 Answers
Answerd
Posted on Jul 13, 2013
  • 624 Answers
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
  • 103 Answers
SOURCE: HP Media-Center M1170N power went
Is the computer doing nothing when you hit the power button, or does it come on but not boot into windows?
Storms can do a lot of damage to a computer even with a surge supressor. With a limited knowledge of computers, you may not want to attempt to diagnose it yourself. Many steps require you to remove pieces of your computer and testing voltage leads. At this point I would say your power supply is a good culprit but I often see the motherboard fail by itself or along with the power supply. If it is really bad, it can take many other components along with it.
I commonly see surges or outages come through the phone line and into a dial up modem also if you use one and sometimes removing/replacing the modem will fix it. If you use high speed internet, sometimes it will come through your cable/DSL line and take out the motherboard also. There are a lot of things to test. You may be better off taking it somewhere to be repaired.
Posted on Apr 23, 2008
SOURCE: HP a350n not powering up.
unplug power and open computer and pull the small battery and wait 30 sec and replace
plug in everything and reboot
may have to re-enter cmos utility
Posted on Aug 25, 2008
rockitman187
  • 2559 Answers
SOURCE: hp media center pc won't turn on after electriticy
Unplug the power cord and hold the power button in until the light on the front comes on and fades out,The plug the power cord back in and start as normal.
Posted on Mar 13, 2009
  • 4 Answers
SOURCE: Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
POWER SUPPLIES HAVE AN INDICATOR LIGHT FOR A REASON.
REMBER - BLINKING LIGHT IS AN OVERLOAD OF THE PROTECTORS AND ELLIMINATING THE OVERLOAD SOLVES THE PROBLEM AND THAT THE POWER SUPPLY IS WORKING AND CONVERTING POWER.
NO LIGHT MEANS NO POWER OUTPUT AND THAT INDICATES THE POWER SUPPLY IS NOT FUNCTIONING AND NEEDS REPLACED.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Posted on Mar 28, 2010
No power when turned on - light green on back - no lights on motherboard - no fans
sunny,try with a other powersupply if possible.
faulty PSU are often the cause.
Jul 13, 2013 | HP Media Center m7250n (ED842AA) PC...
I have a HP M8417c with a 365-Watt Power supply.
The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue..
Feb 18, 2012 | HP 365-Watt Power Supply
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
My HP Media Center m7330n won't power up... The fan comes on but will not boot.. The LED power light blinks at 3 second intervals from blue to yellow/orange.. What is the diagnosis...
You have to check with your RAM sir, if you know to remove the side cover of your CPU(tower) there will be a green colored chip fixed in vertical position in the motherboard if remove it and then fix it properly means you will get the display in yur screen.i will show you the RAM picture2f70f69.jpg
Oct 29, 2009 | HP Pavilion Media Center TV m7330n...
Our HP Media center pc will not power on. I push the button and the button does not turn green or power on. A green light on the back flickers, but that is all. I forgot to ask if it could just be the...
Make sure the switch on the back of the power supply is set to the position that has the line on it. If you still can't get any power, then try another known good power supply, if you still don't get any power then you know the motheroard is bad.
Jun 12, 2009 | HP Pavilion Replacement 200w Micro ATX PS3...
Won't boot. Power light on, No Video Signal message
It's also possible that your operating system has become corrupted. See if there is enough time to boot into safe mode, or choose a boot option to go into the recovery partition.
Have you made any recent hardware or software modifications?
Dec 12, 2008 | Gateway Media Center 610XL PC Desktop
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Hp media center pc 873n
You might need to open the case and make sure that the wires going from the power button are actually connected to the motherboard.
Sep 01, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Power outage, now pc will not power up at all
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
Jun 12, 2008 | HP Media Center m7060n PC Desktop
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
