Question about Toshiba Qosmio Computers & Internet
My Qosmio x770 has stopped working suddenly
My laptop Qosmio x770 has stopped working suddenly while I was using the laptop normally. More details about the problem: - I plug the AC adaptor to the laptop and the Power LED lights up normally - I press Turn On button the LED lights up for less than 1 second and then it turn off immediately with he Power LED. - I have to disconnect and reconnect the AC adaptor to my laptop again to repeat these steps otherwise I cannot interact with the laptop again. Recently I've moved into an area that is very dusty, I suspect that it has something to do with this problem but not quite sure.
jessee007
  • 310 Answers
SOURCE: Will not power up
pull battery and cord. push on / off button for 60 sec. put battery back in and plugg in power and boot up.. something else to try is some one elses battery to boot up in.
Posted on Jan 07, 2008
Pyrhyc
  • 2028 Answers
SOURCE: laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Posted on Jul 15, 2008
fossildude
  • 832 Answers
SOURCE: hp zd8000 wont turn on...
hi thanks for using fixya!!
Try first to remove the battery and connect the AC adapter to your laptop, you will use the power supply directly from the AC adapter without the battery. Turn on your laptop, then if its working normally as it should be,
Then try now to install back the battery then connect the AC adapter, turn it on. If still does not work, perhaps you have a problem with the battery.
If you need further assistance, let me know.
Posted on May 24, 2009
  • 16 Answers
SOURCE: Hp530 turn off suddenly
Get a power charging adaptor from HP (if a smart adaptor) or a generic anywhere that matches your spec. Your device is doing what mine did, but in addition mine beeped softly as a warning of failure. Being a smart adaptor, I had to order one from HP, a generic won't work.
Posted on Sep 05, 2009
podita
  • 324 Answers
SOURCE: My laptop Toshiba Qosmio F45- AV413 doesn't turn on
The memory is very poor, 3 things, Virtual memory, drive space, and finally check for virus
Posted on Mar 11, 2010
Toshiba Qosmio X775 3DV78 shuts down with a click at start up
Well...
Start with removing your battery and assuring your contacts are spiffy-clean! A NEW pencil eraser should do a good job but don't rub so hard you remove the thin chrome plating. Carefully clean the contacts that mate with your battery inside your system too. Shake out any rubber remains,
Now give your X775 a really GOOD charge, If you have the same results it's time to look elsewhere. It may be a faulty power supply?
When possible OPEN your DVD drive. With your battery removed (and drive bay door open) ~ use a air compressor (ala gas station) or air can and blow all of the dust out! DO NOT invert the can as it will deliver LOTS of MOISTURE into your laptop ~ NOT good.
IS your CPU fan is working?... Remove ALL of the dust from your CPU fan AND dust on your cooling fins under the fan too! Dust can cause your CPU to heat pronto. It can also BAKE the silicone seal under the cooling fins... also not good!
Check YOUTUBE to see how to remove your hard drive... honestly, it looks like a very easy job. Just be CAREFUL with the ribbon cable and connector! Will your computer start with the hard drive removed? Shutdown and restart several times... still OK? If so suspect your drive.
With your hard drive out, can boot from a CD/DVD? If so, suspect that hard drive again.
You are in luck because your X775 will support 2 drives! IF a new drive is required install one. Leave your original hard drive out. Once you have your new drive working and all drivers in, shut your system down and install your ORIGINAL drive as a slave or drive 2. YOU MAY still be able to harvest your data from drive 2 to your new hard drive!
IF some of your drivers were missing after your new drive install, you MAY be able to harvest some of the drivers from drive 2 (your original)? Good luck!
Anthony
I encourage you to see YOUTUBE for very good details on your hard drive... IF you go to a pro to do the job BE SURE to have him/her to replace the CMOS Battery too!
How to Add second HDD to your qosmio x770
Nov 29, 2017 | Toshiba Computers & Internet
Toshiba Qosmio x875 keyboard suddenly stops working
pls remove the key board ribbon cable and re seat again
Sep 08, 2017 | Toshiba Qosmio Computers & Internet
Toshiba Dynadock 3.0 mouse and screen lag
You are right, it should not...Check your device manager and see if there is any problem listed there (the little yellow exclamation mark) against the Dynadock. Also check on Windows site if your device is listed as compatible with Win 8 ... Just some ideas, hard to tell just by description.
Feb 19, 2013 | Toshiba Dynadock USB Docking Station
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
I have a toshiba qosmio laptop that stopped working all of a sudden. The problem is it will not start up. What I noticed is that that the power indicator lights on the front that are usually green are...
remove the battery and see if it works fine, use only the power supply. If it works the problem is the battery if not you need to test your power supply. That's the easier way
May 04, 2012 | Toshiba Qosmio F25-AV205 Notebook
Toshiba Qosmio f20 not booting up
Dear Sir,
Try this, remove the power plug and battery, wait for five minutes and plug the computer to power with out the battery and try to start it.
Dec 31, 2009 | Toshiba Qosmio G15 Notebook
Toshiba Qosmio X305-Q705 Laptop screen yellow
It is not a driver or video card problem. It is the monitor.
To be sure plug a full size desktop monitor into your laptops monitor jack. Every laptop has one. If the picture doesn't turn yellow that will confirm that your LCD is bad.
Aug 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Blue lines on Display seen.
that is easy just go to rooftop of the building and throw you loptop ok
Oct 19, 2008 | Toshiba Qosmio F25-AV205 Notebook
Toshiba cooling system
If u have a laptop (that's what i found out that toshiba Qosmio is ) then is no problem that the fans stop (as long as the temp. is within the normal working margins ). U might have a setting problem - a bad software, managing the cooling system; - a bad BIOS setting regarding system temperature protection; - or the temperature detectors malfunctions, and must be changed (if possible)
Jan 14, 2008 | Toshiba (K000016310) Cooling Fan
Computers & Internet Logo
167 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
