Question about Humidifiers
Bionaire air condicioner cf-5500
Water caming from the bac off condicioner
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
Where can I buy spare parts for cf 5500 ?
I would try Servall Corporation for appliance components for most anything. Or do a Web search using the name and model and if that is too general, narrow it down by adding the specific part.
May 08, 2014 | Humidifiers
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
Where can I buy replacement water-tank caps for a Bionaire W12? Also, what's the difference between Bionaire W12 and W12-UC?
i just ordered a replacement cap for the w-12 it has a funnel on the end the one i have don't but the man said it will do the same thing. the funnel is for pouring the water in. the website is appliancefactoryparts.com it cost around 28.00 thats including the shipping and handling of 7.99
Nov 15, 2010 | Bionaire W12-UC Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Bionaire Bcm630
Same problem — junk.  Will return it to Sears (Costco was out).
Nov 18, 2007 | Bionaire BCM6010 Humidifier
Bionaire BCM630
Remove the water tank from the main unit. Now look down into the unit where the water tank sits. There is a small knob that you need to turn counter clockwise and the lower part of the unit incl the filter will slide out.
Sep 23, 2007 | Bionaire BCM6010 Humidifier
Hunidifier doesn't add enough moisture to air
here is the link to the manual for the w7 - they suggest a replacement wick filter would solve the problem due to bacteria or mineral build up - i would expect this to solve your problem as the only way these wicks can not soak up the water to the top is if they are clogged or the tank is empty. try the cleaning routine on page 9 first - might be enough but the wicks probably will need replacing soon anyway. http://www.bionaire.com/manuals/W7_English.pdf Hope this helps :)
Mar 08, 2007 | Bionaire W7 Humidifier
Humidifiers Logo
56 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
