Question about Motorola Mobility Backflip MB300
MB300 SD Card
MB300 does not recognize the SD card.
My 32 GB SD card is not being Recognized for mounting, while my old 8 GB SD card works fine. How do I fix this?
The problem lies with your reader not being able to recognize sd cards over 8 gigs. A newer reader will work.
Apr 18, 2015 | RCA Digital Stream 7 inch Droid Tablet
Insert sd card camcorderst recognize any micro sdcard
If your SP1 camera cannot recognize the micro SD card, please be sure you are using a card between 4GB to 32GB, class 10 speed. If possible, please try another micro SD card to be sure that the card that is not recognized is not defective. If you are using a card with correct specifications and it is not recognized, then the micro SD card port on your camera may be defective. Please contact Intova directly via email: fatema@intova.net or call us at 808-837-0074 for customer service/warranty coverage. Thanks.
May 28, 2013 | Intova SP1 Sport Pro 12.0 Megapixel,140...
SD card not recognized
What happens when you tried to plug-in SD card to the computer?
Have you made any recent changes to the computer prior to the issue?
To make the SDHC be recognized by the computer, we need to ensure that the card reader works in Windows 7 first. Please check if the card reader is recognized properly by the computer and you have installed the driver for it.
Meanwhile, you can plug some other storage cards to the card reader and see how it works.
I would suggest you to refer the link below
A Secure Digital (SD) card may not be recognized on a Windows 7 based computer.
http://support.microsoft.com/kb/981642
Uninstall all the Generic USB drivers and reinstall.
1. Open Device Manager.
2. In "Disk Drives" dropdown, uninstall the "Generic SD/MMC USB device" drive.
3. Restart computer.
4. Insert SDHC card.
Hope this helps.
Nov 25, 2012 | SanDisk Electronics - Others
My phone keeps telling me that my SD card has been removed but it hasn't been. I've tried taking it out and putting it back in but it keeps telling me the same thing
maybe because your phone don't recognize your SD card anymore. try to put your SD card to other phone and try if the other phone recognize your SD card, if the other phone don't recognize your SD card, the problem is in your SD card. you should buy a new SD card if that's the case. Also try to put a different SD card on your phone and you'll see your phone will recognize the different SD card.
Kindly rate this post. Thank you for your question and I hope I help you a lot.
Jan 20, 2012 | HTC Cell Phones
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 23, 2010 | Kodak EasyShare Z740 Digital Camera
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
Computer not recognizing SD card as external storage/Creative Zen
Try going to the memory card option on the main menu, then go to 'Removable Storage', then the Zen should either tell you to connect a USB cord or insert a memory card. Try it, if not I dont know.
Jan 02, 2009 | Creative Labs Zen Digital Media Player
SD card access problem (nuvi 660)
Try seeing if your computer can recognize the card in a card reader. Your SD card might be corrupt.
Sep 26, 2008 | Garmin Nuvi 660 GPS Receiver
Micro sd card
Does your computer has an internal card reader?
Aug 14, 2008 | SanDisk Sansa E280 MP3 Player
2GB SD card no recognized
sir probably your 2gb is dead or not factory formatted... just take your receipts and take that back to where you bought it... if it is formatted probably its the same problems of those who formatted their SD with windows xp... that worsen your problem cause i think you just void the warranty of your SD card... try your SD to other card readers and if something pops like "your drive is not formatted... format i now... just click no"
Jan 20, 2008 | HP Compaq nx5000 Notebook
Motorola Mobility Backflip MB300 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
