Question about Sewing Machines
Tension mechanism my granddaughter took the tension knob off of my machine, which made all the parts inside it, come out. I need to know how to put it back together
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sewing Machines Master
  • 102,366 Answers
What make and model sewing machine?
Posted on Jul 14, 2013
3 Suggested Answers
SOURCE: How do you put the thread tension dial assembly
got it thanks
Posted on Dec 31, 2009
Tally Girl
  • 1133 Answers
SOURCE: I lost my Elna 2110 manual in a recent move. I
you can download a manual from here
http://safemanuals.com/user-guide-instructions-owner-manual/ELNA/2110-_E
Posted on Apr 16, 2011
Thread tension control knob parts list.
There are just so many kinds of tension control knobs. Do you have a photo or model number?
Jan 30, 2014 | Simplicity Sew Precious SWSP2 Mechanical...
Sewing machine top tension discs very loose
repairing it yourself, without any training or mechanical skills could be problematic, given that you have already rejected 'new part' as a solution.
Mar 08, 2018 | Singer 2250 Tradition
Rust inside of tension dial
If your tension knob is on top of the machine, it should be possible to unscrew the knob anti clock wise. Make sure the spring and other washers are not jumping out. Also check the position of the parts to know how to place it back into position once you finished cleaning.
Jan 12, 2014 | Singer Sewing Machines
How do i fix the tension? i've been playing with the knobs for hours, but the threads are still too loose on the fabric.
Try decreasing your stitch width and this should help. Put your tension dials on 4. Also make sure when you thread your machine your presser foot lever is up to allow you to get your threads through your tension discs properly. To test the tension (usually set at 4 on all 4 knobs) when you thread around the knobs pull the thread on both ends like you're using dental floss around the discs under the knobs so you can feel the pull (tension) on the thread. Let me know if this works for you.
Aug 22, 2010 | Juki MO-654DE Mechanical Sewing Machine
Bottom tension too loose.
Is it looping on the bottom of the fabric? If so this is a top tension issue, you need to check some things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset. Let me know if you need more help.
-Chris
Jun 05, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
The thread tension knob came off. I don't know in
The tension knob came off and I need instruction on the order in which it goes back together.
Oct 29, 2009 | White Sewing 1409 Mechanical Sewing...
Took apart tension button on sewing machine
This could be tricky, look on line for a diagram of a typical tension assembly. There aren't that many parts but they can be put on in the wrong order. There is probably a set screw somewhere that has vibrated loose, you need to tighten it after replacing the unit.
Jan 29, 2009 | Janome 2049LX Mechanical Sewing Machine
I took the tension apart for a kenmore 148.15600 model
Hi - unfortunately, putting the tension back together takes alot of training - not only do you have to re-install the parts correctly so the hook is in the correct position and the bobbin is in the correct position when the needle moves down thru the needle plate and into the bobbin case to pull up the bobbin thread. Further, you need to set what called the timing - your needle needs to enter the bobbin dead on center and to a very precise depth. Technicians often use a special tool to set the timing, because each machine has a different a different hook and bobbin case.
I know this won't win me any points, but you will probably need to take the machine to a repair shop to have the hook replaced or reinstalled. If you mechanically inclined, you can search the web for a service manual for your machine - the service manual will illustrate how to replace the hook and specify the timing and needle depth settings.
Good luck,
Ginny
Jan 24, 2009 | Kenmore Sewing Machines
Mylock 134d janome
make sure the needle is pushed in properly.
Jun 24, 2008 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
44 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
