Question about Lexmark X5150 All-In-One InkJet Printer
Black ink cartridge failure
My original black ink cartridge, only used one week, gets black ink goo on the bottom of the cartridge and then has white lines all through print area. I have replaced the cartridge 2 times and after a short time the same problems starts all over. I can clean the cartridge but the problem comes back.
  • 159 Answers
Your printer may not be sealing the print head when it is off or in sleep mode. That would explain the build up over time and the fact that it is fixed by cleaning the print head. If your printer is still under warranty, take it in to get it checked. If it's not under warranty, you may just have to live with the problem or try to fix it yourself.
Posted on Dec 29, 2009
Canon pixma mp150 printer shows error E 2 7 and alarm light is on also cartridge holder is stuck on right hand side and wont slide to the left
If you are able to produce a self test print, this is good since it illustrates that the cartridges are electrically stable...if you observe any 'E' or 'V' error states (i.e. "E xx" or "V162" for example), this may indicate there is possibly an internal electrical problem with one of the ink cartridges. Refer to your user guide if E/V error messages are displayed.
Inkjet411 support page on the PG-40 black / CLI-41 color ink cartridge series: :
If, after following the suggested ink monitoring/level reset procedures, you still have an error condition which prohibits regular printing, then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page:
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions:
Canon 50/51 - Refilled Cartridge Activation Instructions:
If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
However, if your printer works routinely after inserting a brand new PGI-40 black ink cartridge in it, then this will confirm root cause of failure as being limited to the ink cartridge iteslf.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures. We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
Canon 30/31 Ink Refilling Services & Additional Cautions:
Canon 40/41 Ink Refilling Services & Additional Cautions:
Canon 50/51 Ink Refilling Services & Additional Cautions:
If you ever need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (these are remanufactured ink cartridges which have been pre-tested in an actual printer; purchases are only available to USA residents).
Please let us know if you have any questions regarding the technical information provided herein. For any additional questions please contact us directly:
Feb 24, 2015 | Canon Pg-40 Black Ink Cartridge Pixma Mp...
Get the esp 2170 to not print light green instead of black ? I keep on replacing cartridge , to no avail !
replacing a cartridge, while the nozzles are blocked won't help.
Realise the printer will mix there colours to get "black" on the paper. So even a full cartridge, can't make the other colours black till the blockage is gone.
Please try this. If you have ink cleaning fluid, (only for printer ink) use that, if you dont have cleaning fluid, use clean water.
Open the printer as if you replace a cartridge. Remove the black one and look tot the bottom of the cartridge holder. There is a little pipe, where the ink should go in. put some drops water or cleaning fluid in there leave it a few minutes. with a tissue dry it and again insert some drops of water or cleaning fluid. Then put in a cartridge and give the printer a black and white print job. Like print a few A4 papers. Let it print till the black comes back. Can take up to 4 pages A4. I hope this will unblock the nozzles.
Please even if you don't need to print, switch the printer on at least once a week. And even better, let it do a bit of printing every week. This will save a lot of frustration.
Dec 03, 2014 | Kodak ESP Office Equipment & Supplies
I rwplaced the black ink cartridge a week ago. Now the printer says the colored ink carftridge is emty aand it will not let me print. I only want to print black and white and not able to get to a store...
The only way to solve the problem is by replacing the color cartridge.
If you only want to print black and white get a black and white printer.
Sorry, but that's the cold hard facts.
Apr 09, 2011 | Office Equipment & Supplies
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Will not print in black.
1st clean heads, on printers menu, then check if you have instaled non canon ink cartridges, you maybe burn out ink printheads. ONLY USE ORIGINAL INK CARTRIGES ALWAYS.this a normal failure on NON CANON INK SPARES.
Nov 22, 2009 | Canon Office Equipment & Supplies
Want to print only black and white, not colour
If you buy a printer with both a color cartridge, and a black cartridge, you must have both cartridges in the printer for it to work. I don't know of any ink jet or lazer printer that will work without all cartridges installed and in goo shape.
Mar 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Lexmark X2600 printer will not print in black and white
you may check your only black ink cartridge
longer time less using cause ink chanel(holes) dryer, could not print out even may take out the ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X2600 InkJet Printer
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark X5150 All-In-One InkJet Printer Logo
802 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
