Question about Beltronics Vehicle Parts & Accessories
Bel 645i displaying error and beeping is there a way to reset it
Display panel on fridge door display flashing from 4 to 7 and beeps 5 times.
the blast chiller fan has prob failed
also check the thermal fuse on the heating elements that are around the chiller elements {used to defrost the chiller section}
and if there is also one on the fan check it
the beeping is prob an error code
you can consult the manual or phone the makers support number
to get more info on the exact error detected
usually there is some reset error like hold in the button etc and power on then let it go
more any more appliances have this
and if you dont know to reset
even if the error is cleared the unit will remain in this error mode
till reset again check the manual
Jun 19, 2014 | Amana SXD524VW Side by Side Refrigerator
Bel 645i is there a reset
Pull the power plug and wait a few minutes and it should reset (if that will fix it)
Jul 13, 2013 | Vehicle Parts & Accessories
BRAKE RESOVOIR BMW 645I
under plastic cover what are the engine as wipers and microfilters (driver side)
May 09, 2010 | 2004 BMW 6 Series
Our JTP15 beeps and displays F7 is there a reset for it?
Yes, you will need to press the stop/cancel button, this will clear the error code and the display.
Nov 14, 2009 | GE JTP15 Electric Single Oven
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
No display
Have you tried doing a factory reset of the firmware as described in the user manual? To do this, first power off your RX65 using its power button. Then hold down the two buttons which are used to enter Program Mode and, while holding down these two buttons, press the Power button again. Release all three buttons when the word "Reset" is displayed on the LED display. Obviously, if the display doesn't light up, then either the display itself is defective or one of its display leads has a cold solder joint.
If your RX65 is in warranty and you can make a photocopy of your sales receipt, then Bel will repair it at no charge. You will have to pay the shipping cost to Bel.
Mar 23, 2009 | Pro RX65 Radar Detector
No audio
Hi everyone,
Bel/Escort now uses a special and proprietary "high temp" speaker which resolves issues of speakers blowing due to high ambient temperatures or heat which builds up within the speaker when it is alerting for extended periods of time. If your RX65 is in warranty and you can make a photocopy of your sales receipt, then great! All you have to pay is shipping to Bel. Bell will replace the speaker with the new version, flash your RX65 with whatever the latest firmware is, and calibrate and test your RX65 too. So, all of this is peachy if your RX65 is under warranty.
If your RX65 is out-of-warranty or if it doesn't have a serial number or was bought from a non-authorized dealer, then the service charge as I recall is $80. Thats not bad since your RD will come back working like brand new.
A note about the speakers: They are made by PUI, but the speakers are proprietary to Bel/Escort. Thus you can not buy them from any source -- not even direct from PUI.
Dec 15, 2008 | Pro RX65 Radar Detector
Error code F 1 stove beeps
Hello rusalderman,
Welcome to fixya.
Happy to help.
You said, your range has an error code F 1 stove beeps.
This should reset the system.
A Solution to Common Problems
Oven control beeps & displays any F code error (for example
F1) - Electronic control has detected a fault condition.
Press CLEAR/OFF to clear the display & stop beeping.
Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF &
contact an authorized service agent.
This should resolve your problem and reset the system.
Please remember to leave a rating when you are finished.
Let me know. Hopefully it will be a solved.
Thank You , Huuum
Oct 02, 2008 | Frigidaire Kitchen Ranges
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
No sound, voice or beeps
Good Day Joe,
Sounds to me like the internal speaker went, this is actually common on radar detectors. Although 9yrs is a lot longer than most will last. If you are handy with a soldering gun you can replace the internal speaker with a new one and get it working again. However be sure to take the unit apart before getting a new speaker so you can match up the size as it varies.
Good Luck and I hope thi shelps
Jul 04, 2008 | BEL 950 Radar Detector
Vehicle Parts & Accessories Logo
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
