Question about Fujitsu LifeBook C2330 Notebook
Computer wont charge ,and starts for only 30 seconds or so.
My 2 year old galaxy tab 4 won't charge
Disconnect charger
Hold power button and volume up button for 30 seconds
Keep holding buttons while plugging in charger
Hold buttons for another 30 secs
Release power button keeping volume button pressed
Tab starts to charge
May 22, 2017 | Galaxy Computers & Internet
Asus wont start up
Put a bit of more pressure on the power button and move your finger around it a bit. It's possible the button could have dislocated. If it does not turn on, then it could be a problem with your laptop's motherboard, or something else inside preventing it from powering on.
and try :-
Remove the power supply, and then take out the battery.
Hold down the power button for 15 to 30 seconds...then put the battery back in and plug the power supply in.
Now press the power button again.
Jul 08, 2013 | Computers & Internet
Laptop battery charges for 30 seconds and then stops
Dear Lauren Monge
The problem is in one of two,1st charge plug in your lap or the adapter itself and its plugins
Best Regards
Mazagange
Mar 28, 2013 | Dell Vostro 1710 Laptop
Mini 1012. new battery. charger led working, battery wont charge. when plugged in charger works for about 30 seconds
Seems like you may have purchased the incorrect battery or they shipped you one that is NOT for your unit, if you purchased an "aftermarket" battery this could be the issue. Not saying aftermarket parts are bad, they are just massed produced and sometimes you get a bad one. Return it for refund or replacement. Try E-Bay for a reseller for this product, much less cost.
Jan 28, 2013 | Dell Inspiron Mini 1012 Netbook...
Hi since my battery went flat my car wont start due to the immobilizer not working my key still works to open the car but wont start it, i have tryed to reset the immobilized but it didnt work and i d
try unlocking your doors manualy one at a time then try if it dont work them cheapest way is to call a lock smith some of them have the programer and there only arround $ 150 bucks ok hope this helps
Nov 13, 2012 | Cars & Trucks
My galaxy tablet GT-P7510 wont turn on its fully charged
Hold down power up button until it starts. It can take up to 30 seconds before it restarts.
Sep 29, 2012 | Samsung Galaxy Tab GT-P7510MAVXAB Tablet
Acer x3400 wont start up
Remove the Power Cord and then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in and press the power button. If it reboots you had a Static Charge Buildup and released it by holding the power button for 30 seconds.
When you press the power button do you hear the fan running, disk drives running, cd drive clicks once, anything on the lcd screen? If not I would think your Power Supply is bad and needs to be replaced.
It's either the Power Supply or Motherboard.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
I have a dodge caravan 2002 it wont charge put on new alternator, and computer. it still wont charge. the wire on the back of the alternator is not showing any fire?
Why do you feel it isn't charging. Are you going off of a voltage ereadiing? I ask because if it is reading 12 v at the battery , Do not run it very long. The lower the voltage the higher the amps. An Alternator will ocweheat and self destruct if it is working at its high limit for 15 minutes or so. A heavy charge iis normal for 30 seconds or so to make up for the starting drain. But, should show a gradual rise within seconds. An alternator is for battery charge maintenance only and should never be used to charge a dead battery. A dead battery can an will over tax the alternator for too long. A defective battery will do the same thing and it is usually why you have to change the alternator in the first place. So, If your battery is dead or extremely lpw, it should be charged with a charger Do not put a new or rebuilt Aly. sgainst a possible bad battery. It costs nothing to have your batt load tested by a auto parts store. Good Luck=Ned-.
Sep 17, 2009 | 2002 Dodge Caravan
Renault espace 2.2d.c.i new battery turns over wont start.
could be one of many probs check your altenator is giving a charge to the battery any garage could do this for you it only takes 30 seconds and most reputable garages wont charge for this
Sep 03, 2009 | 2003 Renault 181
I have a 2002 Oldsmobile Bravada. Today when I got in the clock had went back to 12:00.. it was 3:30. Then tonight the automatic lights wouldn't turn off (headlights and all usually turn off with in 30...
Sounds like you have lose wire in the door switch try charging your Battery up again and see what happens when you push the button in the door frame in and let it pop back into position by default a power surge or a short will reset your clock back to start at 12:00 and if its not working correctly or a wire has become dislodged and found earth the lights will remain on until the computer turns it of when the charge is only enough to keep the computer going to unlock an keep memory alive. Replace switch or rectify the problem and let me know how you got on. Goodluck Ron
Dec 07, 2017 | 2002 Oldsmobile Bravada
Fujitsu LifeBook C2330 Notebook Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
