Question about Garden
Search Fixya...Model #316794400 Craftsman Gas trimmer recoil starter rope replace
How to replace recoil starter cord on Model #316794400 Craftsman Gas trimmer
  • 1,807 Answers
Https://www.youtube.com/watch?v=X0wnAl_mV80
Try looking on youtube. There are many helpful videos on there
Posted on May 21, 2016
2 Suggested Answers
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
How to replace starter pull cord on model no. 358791580
I'm sure i've seen a video showing you the process on youtube of how to replace the recoil.
May 09, 2016 | Craftsman 32cc* 4-Cycle Straight Shaft...
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Yes, I have a Craftsman 25 cc Gas Trimmer and we just snapped the starter cord. Do you have to open up the head to fix this? Does it need a special type of cord?
Yes you have to remove the plastic recoil assembly and install a certain size cord. We use a #3 or 3.5 cord on all our string trimmers, blowers with that size engine.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
How to change the starting rope of weedwreker 32cc.
I know this info isn't in the users manual and I haven't found a "repair"manual yet but there is probably something out there. Some disassembly will be required for you to reach the point where you can actually service the starter/recoil unit with new rope. Torx head screws are used exclusively on these units and some patience and diligence will get you to the recoil unit. Be forewarned if you do it yourself....there is some work involved removing items.
Aug 20, 2010 | Craftsman 25cc Gas Line Trimmer
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The start up cord get stock often
The rope rotor is damaged or the recoil spring is weak. not a fun thing to do.
Jul 02, 2010 | Craftsman 25cc Gas Line Trimmer
The starter rope won't recoil back
disasemble again this time before winding cord twist housing counter clockwise till you feel tension good luck
May 09, 2010 | Craftsman 25cc Gas Line Trimmer
Rope to start want recoil
The starter pawls on this model are exposes to weather. You can usually spray WD-40 directly to the flywheel pawls and loosen with a screwdriver.
Apr 30, 2010 | Craftsman 25cc Gas Line Trimmer
Garden Logo
167 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
