Question about Minn Kota Endura 40 Transom Mount Trolling Motor with 36" Shaft
Reverse is forward and vice versa
I recently replaced the brushes and springs and now forwards is backwards and vice versa. I've turned the housing 180 degrees and switched the wires on the brushes with no luck. I've heard the brushes could be upside down but it looks like that wouldn't make a difference
    Top Expert:
  • Minn Kota Master
  • 50,503 Answers
To get a dc motor to spin in reverse you have to change the polarity of the battery. This is normally done in the switch by which set of poles is connected . Have you connected the battery up correctly in the first instance.
Posted on Aug 07, 2013
What results happens when motor brushes are going bad
Based on your description you should purchase new motor brushes for both motors and replace them. This will be a short term improvement. You should block up the chair in the air and run in the brushes by taping the joystick forward and running the motors forward for 1 hour and in reverse 1/2 hour NO LOAD. This will seat the brushes on the armature, that is, get a curve on them. If your budget allows, prepare for motor gearbox replacement in the next year.
Jul 23, 2014 | Pride Jazzy Select Hd JSELECTHD
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Analog Sticks Inverted on PC
Yeah, I don't use third-party controllers on my PC, just the Xbox controller. I'm sorry that you have this problem with other controllers.
Jan 16, 2013 | PDP Rock Candy Controller For Playstation...
My heater works sometimes but mostly cold air
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
Feb 26, 2018 | 2002 Pontiac Grand Am
How much forward and backward slop should there be on the mainshaft 1st gear when i turn it back then forward on the clutch side
When you've got the clutch off and you're turning the mainshaft by hand backwards and forwards, it feels like a lot. I've never measured it but it seems like it's about a half turn or so. What you are doing when you turn the mainshaft backwards and forwards with the transmission in gear is you're moving the dogs of the first gear clutch dog in the transmission back and forth in the slots that it the dogs fit into. They have to have enough room to slide into the slots but when it the engine is running. the dogs go all the way to the backside and stop. Unless you're having a problem with the transmission, don't worry about this back and forward movement.
Good Luck
Steve
Jun 17, 2011 | 2003 Harley Davidson FXD Dyna Super Glide
Push forard on the drivers side electric set and
It isn't wired wrong. Mine does the exact same thing, but it didn't used to be backwards and the wiring has never been changed.
Jun 05, 2010 | 2004 Chevrolet Suburban
Polarity reversed on power seats ...when attempting top move power seats to the forward position..the seat moves backwards and visa versa.
It shouldn't be possible to invert connector plug but what ever you did prior to this situtation is suspect ! Try reversing the plug wiring , It's designed to turn in both directions and will not damage the motor ie back / forward. Good Luck
Apr 11, 2010 | 2003 GMC Yukon
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 | Garden
Minn Kota Endura 40 Transom Mount Trolling Motor with 36" Shaft Logo
160 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
