Question about iHome IDM8 Bluetooth Speaker Black
Power button stuck - iHome IDM8 Bluetooth Speaker Black
Keurig power button
I am not familiar with the button itself but I am familiar with stuck buttons. If this is an analog (push down button then is most likely stuck in cover or housing. For this you can use a pin or small screwdriver and gently pry it back out from the side it is stuck on. If this is a digital (touch button) then you will most likely have to replace the board it is on. One thing you can do is take it apart, unplug the board the button is on, leave it for a few seconds and plug it back in. That might reset this.
Jul 12, 2014 | Keurig Vue Brewing System
DRIVER POWER SEAT LUMBAR BUTTON STUCK. SEAT DOESN'T MOVE
Remove the button & resolve that part of the issue,
so it either works or if tests bad-- replace it
Dec 07, 2012 | 2010 Chevrolet Silverado 1500
I have a Dell Demension 5100, and the power button got stuck. By stuck, I mean that the power button is pushed in, but not released. It's stuck as if you pressed the power button, but did not release...
if your PC have restart button then open your PC and check the power cable slots and change them into a reset mode removing reset cable to reset slots and attach to power slot. Then you can power your pC with reset button. If you can open front case then you can outside the button .
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Button stuck
Please remove the unit from any power. Once you have, please replace the unit to find that the button is no longer in the stuck position. Please do not attempt to troubleshoot the button when and IF any power is being applied.
Jan 09, 2011 | Thermasol Steamshower Generator Classic...
Power button is stuck. What can I do??
A Product called "Air Duster" is available in market. Its a pressurised Air Tin which can eliminate switch stuck problem.
you can use this for the parts like Keyboards, mouse etc..
Mar 26, 2010 | Dell E228WFP LCD Monitor
Power button stuck in 'Off' position
My CHI button is stuck on off, how do i fix it ?
Aug 01, 2009 | Wahl Health & Beauty
Power button stuck in off position on Dell Flat screen Monitor
Does the button move at all? What model LCD is it? Most of the time if the monitor does not power up it is the power supply inside the monitor not the button sticking. The power supply can be repaired if that is the problem. Please let me about the movement on the power button and I can help you get back going with your monitor.
Buddy
Corporate Computer
Jun 17, 2009 | Dell E176FPC Monitor
Toshiba CF32D40 Power button stuck-will not come on.
Did it out with a screw driver if you don't mind breaking the power button that most folks don't use thanks to remote. See if that works.
Oct 20, 2008 | Toshiba 32AF43 32" TV
iHome IDM8 Bluetooth Speaker Black Logo
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
