Question about Raymarine St1000 Plus Tiller Pilot
Autohelm 1000 my st1000 gets stuck on 78 degs, I leave it on standby for an hour or 2, if I'm lucky it comes good. I am on a small cat sailing north in Aus. It does get wet. I open it up in attempt to dry out in the sun. Is WD40 an option?
4 Suggested Answers
  • 64 Answers
SOURCE: I have a autohelm 1000 digital & the owner
Any GPS that outputs a NMEA 0183 signal will work with this autopilot.
Posted on Jun 14, 2010
  • 38 Answers
SOURCE: I have an old autohelm 800 analog with turn
If it is the one with the compass rose on it ,check if the compass rose is turning while the arm is moving,if not take the compass dial off by lifting the rose on the compass dial and unscrewing the special screw,then the same for the function dial.and all the screws in the bottom , Inside is a string with a spring running around the compass and on a pulley check if the string is broken or off the track.
Posted on Jun 22, 2010
SOURCE: My Raymarine ST1000 12 months
I have the same problem. Do you have a solution for it yet?
I do think it has to do something with decreasing power from my onboard accu. The first hour(s) sailing I don't have any problems, but after a while mine is jumping to STANDBY too, and the periods between become shorter, until less then 5 minutes.
Posted on Jun 17, 2011
I'm trying to fix an autohelm 1000 and ned the schematic
Go to Raymarine website and look under Technical Support, Manuals and documents. All of their product manuals are listed there. If you are burning out the transistors, it sounds like you are puting too much load on the auto pilot.
Dec 05, 2013 | Raymarine St1000 Plus Tiller Pilot
Just interested on ''how'' the Autohelm ST1000 Plus works! is there somewhere on the net that I can check, I just bought a boat with one one it and I know how to make it work, but I want to...
Hi!
The ST1000+ does not have an internal GPS. What it does have is an electronic compass underneath the keypad. When you order the Tillerpilot to steer to a bearing, the unit uses the electronic compass to steer using a series of corrections.
Just in case you've misplaced your Owners Manual, you can use this link to download it to your computer: http://www.raymarine.com/productdocumentfinder.aspx
Click on your language preference, then Autopilots from the drop-down menu, tillerpilots and finally ST 1000+. The pdf file for your unit is 81130_6.pdf
Hope this helps and happy boating!
Jun 14, 2011 | Raymarine St1000 Plus Tiller Pilot
My Raymarine ST1000 12 months old, started cutting out a couple of months ago and displaying 1000 them return to standby mode. The frequency of this happening has increased 10 fold. sometimes it happens...
Jan 10, 2011 | Raymarine St1000 Plus Tiller Pilot
I got a Raythoen ST1000 tiller pilot with my new yacht but its still in box without wiring or any other instructions. There is a six pole socket on the cable and I need to identify which is power and -...
Hi!
As you're looking at the tillerpiot receptacle from the back, rotate until the "keyway" on the front is located in the one o'clock position. Your 12v power supply (pin 1) will be slightly below 9 o'clock and your ground (pin 2) will be above pin 1.
Other pinouts designations:
Pin 3= not used
Pin 4= SeaTalk
Pin 5= NMEA -
Pin 6= NMEA +
Your owners manual can be found on the Raymarine website here:
Use the drop-down menus to select Autohelm 1000+
Hope this is helpful!
Sep 11, 2010 | Raymarine Boating
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
I have an old autohelm 800 analog with turn dial worked ok for three year on my 20ft sail boat Coreis but the other day it fully extended the arm and now it just 'clicks' and will not respond to turning...
I have a good one but need the mounting bracket that attaches to the side of the sailboat. So if u no longer need urs let me know price. Same for the electrical plug. Thanks
paul pebrown1@yahoo.com
Jul 10, 2009 | Raymarine Boating
5vz-fe misfire codes
Replace the coil pack.
Dec 26, 2008 | 1999 Toyota 4Runner
Boxs for northwest
00: c3 40 78 a2 b2 1c 84 f9
01: fc 5b d3 21 c4 e0 7a fe
please leave a ranking thanks and good luck
Jul 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Raymarine St1000 Plus Tiller Pilot Logo
74 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
