Question about Miele S7210 Bagged Upright Vacuum
Assembly I disassembled my miele s7210 because of a blockage. Fixed that but now I can't re install the rear wheels properly.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 62 Answers
The gears on the rear wheel assembly have to be aligned properly before they can be fastened in place, otherwise the rear axel will be crooked and and will not sit level. Your post is from 5 months ago, have you resolved the issue yet?
Posted on Nov 15, 2013
3 Suggested Answers
small6363
  • 18394 Answers
SOURCE: Miele S7210 upright how do I remove a split hose from the handle end
THIS LINK IS THE MANUAL
http://www.totalvac.com/manuals/miele-vacuum-S7000-manual.pdf
Posted on Oct 16, 2012
kevin_getz
  • 1031 Answers
SOURCE: miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
Posted on May 12, 2012
The red light comes on the nothing else. There doesn't appear to be a blockage.
Hello there, at the risk of insulting your intelligence...
It doesn't need emptying does it?
May 28, 2016 | Miele Vacuums
The hose is blocked, how do I get it off to unblock?
Hey, this is Tristan with Crucial Vacuum,
In order to remove the hose to start unblocking it, do the following:
1. Put the vacuum in the upright position
2. Press the release button of the telescopic wand and remove the handle from the hose
3. Push the hose elbow downward into the catch hooks.
4. Undo the suction hose by twisting it at the elbow.
If the blockage isn't in this location you can do the following to search further for blockages:
5. Open the service flap on the back of the vacuum.
6. Unscrew the screws and pull the cover free.
Below I have attached a link to the users manual for the Miele S7210. You should refer to page 30 to view the diagrams pertaining to my suggestions.
http://www.sylvane.com/media/documents/products/miele-s7210-twist-upright-vacuum-users-manual.pdf
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Tristan Clausell
Crucial Vacuum Customer Care
Oct 14, 2015 | Miele S7210 Bagged Upright Vacuum
From the first day the dust, carpet, etc.. has been coming out of the vacuum - all over, every exit point, the top is covered in dust, clumps are pulled from under the hood, and even within the extension...
Verify the bag is connected properly or that the bag is not cut. Was there some shipping spacers that you were to remove before use? Look at the owner's manual again. Good Luck
Jan 15, 2014 | Miele S7210 Bagged Upright Vacuum
When the brush is on it won't **** properly
Look for blockage carefully as the unit does not know which you have attached.
Dec 05, 2012 | Miele S7210 Bagged Upright Vacuum
How do i detach hose to remove blockage?
Lift the hose out as if you were going to use the attachments. At the base of the hose there is a swivel to adjust the hose 90 degrees. Where the lower section of the hose attaches to the swivel you will see that if you give the hose about a quarter turn then lift, it should come off to check for blockage. Also check the rear suction port located near the hose swivel for blockage. It resembles a parallelogram in shape and come off with 2 visible plastic screws.
Apr 27, 2012 | Miele S7210 Bagged Upright Vacuum
The bag on my s7210 doesn't seem to fit properly and I am getting dust in the bag compartment instead of teh bag - what am I doing wrong?
Check to see that the bag mounting bracket and torsion spring are in place, the bracket will be either a dark graphite color like most of the vacuum or green. If you only have a protruding tube where you put the bag on, then your bag mount have come off and you should order a new one; very inexpensive and it comes with a new spring.
Oct 17, 2011 | Miele S7210 Bagged Upright Vacuum
I'm trying to get my S7000 Miele to stand upright an lock in this position. It wont , i tried to see if foot release was jammed but cant tell it doesnt seem to release to let it move upright an lock in...
There is a rear dust cover that sometimes gets stuck, this will make it almost impossible to lock the handle up. First locate the cover which is at the rear right above the wheels. It's about 2"x8" and ribbed vertically and slides up behind the rear panel of the lower body. If it's in there and stuck, just realign it with the 2 grooves on each side or remove it completely; it is a dust shield after all. The best fix is to replace the rear panel and dust shield and they are ordered together and the cost is fairly low. Also check the alignment of the rear body panel at the bottom There are 2 tabs that protrude down about and inch on each side, the one closest to the handle release lever sometimes gets bent and causes the unit to jam. If this does not help there is one more solution involving the rear wheel assembly. check to see that the rear wheel axel is straight, meaning both wheels are parallel at all times while releasing the handle. If the axel is crooked, the wheel assembly must be replaced and you should have a Miele service center order the part and do it for you.
May 01, 2011 | Miele S7210 Bagged Upright Vacuum
Miele S7210 Bagged Upright Vacuum Logo
161 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
