M2n68 la computer wont power on
I have a m2n68-la motherboard in an hp pavilion p6000 and or some reason it will not power on. power supply is good and i just replaced the power switch. what do i need to do next?
    Brigadier General:
  • 3,400 Answers
Steven, you should make sure all electrical wires from the frontpanel
to the motherboard are in there right places,seated tight and firm.
Posted on Jul 13, 2013
    Scholar:
    New Friend:
  • 85 Answers
This is a well known faulty MB & it is not wise to throw good money after bad. Let it go, I know it hurts but let it go.
  • 1 more comment
  • steven mead Jul 14, 2013
    By this, do you mean buy a new motherboard?
  •  Brad
    Brad Jul 14, 2013
    After I did testing & research of my dead p6000 I parted it out sold the HD., Ram, DVD drive & wireless card. Then recycled the rest.
  •  Brad
    Brad Jul 14, 2013
    You may need to repost your question. I know less about how this site works than I'd like. But it seems that once anyone gives an answer to a quetion, that question is removed from the unanswered quick view list.And I can't figure out how other techs can find it & join the discussion. No help menu here. If you repost I'll not give an answer so some one else can.
zohail
  • 1223 Answers
SOURCE: Bios for Asus M2N68-LA motherboard to run on Win
If this is an OEM HP motherboard, you most likely won't find support on the Asus website since they don't support OEM motherboards. Asus only supports retail motherboards. You need to determine which HP/Compaq pc system this motherboard came installed in, then check the OEM vendors website to see if XP drivers are available. You won't find them on the normal system driver page since it was only shipped from HP/Compaq with Windows Vista installed. One such pc system that used this motherboard is the Presario SR5019UK. I'm sure there were other pc models that used it as well.
Motherboard specs
A good place to start is the HP talk forums.
pls rate me FIXYA if u want more help
Posted on Mar 13, 2009
DickCanFixIt
  • 948 Answers
SOURCE: want the best bios for Asus M2N68-LA motherboard to run on win xp
You don't need to change the bios to do that, you already have the best one.
Posted on Mar 14, 2009
  • 16 Answers
SOURCE: Gigabyte GA-8SIMLNF Rev 1 motherboard specs + help
The following power supply unit (PSU) should work just right, however, it will not fit in a company branded case such as HP, Compaq, Gateway, Dell, etc. sine they all use proprietary parts and cases:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817339019
Posted on Jul 03, 2009
  • 7 Answers
SOURCE: ASUS M2N68-LA Motherboard beeps
The short then long beep error is indicative of a RAM memory issue. I had the same problem and had to use a process of elimination to determine the bad RAM. Place a RAM stick in slot 1 one at a time. The RAM stick(s) that give the short-long beep error are bad. If all RAM gives you the error it is more likely you have a bad board
Posted on Dec 26, 2009
SOURCE: My hp a6130n desktop computer won't turn on after
i got the same problem accept it didnt involve lighting storm thunder when i turned it off then i try turning back on it would start any help seems like the motherboard is fine the lil green light on back is on also can figure the problem help plz?
Posted on Jun 24, 2010
Pegatron M2N68-LA
they are number one on the cables are red
Feb 28, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
HP P6000SERIES
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... This is a common power supply that can be purchased just about any computer retailer - BestBuy, MicroCenter, Amazon.
Very cheaply priced, very functional. Even the generic brands.
Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Feb 21, 2013 | HP Computers & Internet
Having problems with Bestec ATX-300-12z power supply.
Nov 14, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
M2n68-la beep codes
Whenever electronics devices give high pitched beep, it generall means a future failure . There could be reasons for the same.
1. Static built up on the motherboard
2. Conflict on the USB ports.
Troubleshooting 1 :
1. Diconnect all the wires from the tower, including the power cable. Press and hold the power button in the front to remove any static from the motherboard.
2. Check and try again the devices on the USB port.
Troubleshooting 2:
1. Check USB ports for damage , try connect the device to the back of the tower.
Troubleshooting 3
Clear the motherboard setting , use the link attached and see clearing the BIOS settings
Thanks for using fixya
Proton
Jul 07, 2012 | Computers & Internet
M2N68-LA (NARRA3-GL8E) Motherboard Manual - ASUS Owners User Manual
There has been a lot of confusion going on around the net. However I find the driver which should work just fine with your model. However the driver is from HP/COMPAQ and the model is M2N68-LA (Ivy8)
You can download the drivers from this link
Documentations will be available here
If you have doubts let me know.
Nov 04, 2011 | ASUS M2N68-AM SE2 Motherboard
I Have a HP Pavilion a6110in PC. Procesor AMD Athlon 64x2 3600+. Its motherboard have problem.I want to buy a motherboard for it. Request suitable motherboard and price at Visakhapatnam (India)
i believe what you need is this p/n CG781-69002, Motherboard (system board) Narra2 GL8E - This is a micro-ATX form factor, Asus M2N68-LA, Socket AM2 (Athlon 64, Athlon 64 X2 with Dual-Core and Sempron) CPU supported
is your computer p/n GG781AA ?
Oct 19, 2010 | HP Computers & Internet
HP Pavilion a6000n PC. M2N68-LA (NARRA GL8E) motherboard. This motherboard can hold 4GB of memory. I bought 4GB of PC2-400. Problem 1: When I install any of the sticks of memory the BIOS shows them as...
if you are using a 32 bit operating system it will not recognize all of the memory in some instances or the mobo is not designed for more than 2 gb maximum check the mainboard (motherboard) website for specs on your model. sometimes you have to use 64 bit operating system to be able to get the full use of memory over 2 GB
Jul 23, 2010 | HP Pavilion a6000n (882780985018) PC...
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
