Question about Kingston Technology RAM Modules KFJ-PM313/8G Memory - 8 GB -
Ram Memory i bought a 2gb kingston's memory, i had 2gb of memory(2 1gb slots), when i run my pc, it recognize like a 3.25 gb, so the question is : why din't recognize like a 4gb, thanks
  • Kingston Master
  • 5,186 Answers
What OS are you using? If you have a 32-bit OS, this is the normal behavior. The extra 0.75 GB isn't directly addressed by the OS; it will be used for part of the memory cache. If you had a 64-bit OS, you would either see the full 4GB of memory or have a POST memory error on boot.
For most Windows OS versions, you can check your version by going to the System Control Panel. On XP through Windows 7, click Start > Control Panel. Then go to System and Security > System. If you do not see x64 at the end of the OS title, you have the 32-bit OS. For Windows 8 from the desktop, use the Charms menu (Win+C) or Windows Tools menu (Win+X). Then from Charms, select Settings and then Control Panel. From the Tools, go to Control Panel. Select System and Security > System. Read the line "System Type" in the System section.
I hope this helps.
(My old system could not support a 64-bit OS due to the CPU; I still put in the full 4GB even though it wasn't fully accessible.)
Posted on Jul 13, 2013
Memory support
  1. 2 DIMM memory slots (supports up to 2GB memory)
  2. Supports 1.8V DDR DIMM
  3. Supports DDR2 533/400 DIMM
Note2: Use of a Double-Sided memory module (the single chip is 512 Mbit) is required if you wish to install a 1 GB memory module
Only supports one gig per slot...
Mar 21, 2012 | Gigabyte GA-8VM800PMD-775 Motherboard
RAM PROBLEM ON INSPIRON N4010
Go into your BIOS and set it back to factory default. After you do that look at the page that lists your memory and see if both 2GB memory sticks are recognized. If one of them still isn't being recognized. You'll have to physically go inside of the computer and look at your memory slots to see how much memory is in each slot. Its possible you might not see both 2 GB memory sticks. If you do see both then one of them might be bad and you would need to talk to that tech shop to get it replaced.
Feb 06, 2012 | Dell Inspiron N4010 Notebook
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
I have bought a kingston DDR2 ram memory (800 mhz, PC6400, 2GB = 1x2GB) and my motherboard recognizes only a half of it (1024). What can I do to fix it?
If its one RAM den be sure it is 2 GB if 2 RAMS den please see that have you fixed the RAM properly..Try taking out the RAM and clean the lower portion with a clean Rubber/Eraser and dne fix it back properly..
Mar 27, 2010 | PC Chips P23G Motherboard
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Dell M60 only recognizes 1GB of ram; used to see 2GB.
Is the memory the same size ?and belive it or not some machines don't reconize ram even thought it is installed ,if it is running good and your os reads the ram
don't worry about it if not let me know
Dec 24, 2009 | Dell Precision M60 Notebook
Possible ram problems
Try to change the memory slot of each RAM module and run the test again..
Mar 25, 2009 | Kingston 2GB PC2-5300 DDR2 Desktop Memory
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Kingston Technology RAM Modules KFJ-PM313/8G Memory - 8 GB - Logo
60 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
