Question about Garden
New craftsman 26hp gas out exhast
New mower 26hp briggs platnum gas running alot out exhast on first start no start took choke off it started smoked alot cleared up seams run good now no gas should i keep or take back will thanks jim
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Sounds like the float in the carburetor is not functioning correctly.
After the mower was turned off did gas start to drip out by the carburetor?
Posted on Jul 15, 2013
ccrozier_agr
  • 36 Answers
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Posted on Nov 29, 2008
  • 56 Answers
SOURCE: 18.5 sears craftsman yard tractor won't run right
The fuel filter needs replaced or the carburetor needs cleaned.
Posted on Apr 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
they were in/out.
Please do not forget to rate me, Thanks
Posted on May 26, 2010
rycgl
  • 1545 Answers
SOURCE: HI there, I got
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Posted on Jun 05, 2011
Craftsman Briggs & Stratton lawn mower 450series, only used3 times and it will not start? Has oil, gas
Hi Elva
If the mower has been sitting for a while the plastic carburetors have a tendency to plug up. If I remember correctly the choke is attached to the governor. If you can empty the old gas and fill the tank up with 93 octane and let it sit for a couple of day's it may start. I had the same problem. Thx
Jul 28, 2016 | Craftsman Garden
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Craftsman mower with 26hp kohler smokes
Check the oil and let it run to see if it clears up. Sometimes the oil will run into the cylinder when it is jacked up.
Jul 16, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman mower with 26hp kohler smokes while cutting.
it sound like you put to much oil in it.if not check vent valve
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
No power/rough idle/black smoke
either the choke is closed or the float is stuck open..if the float is stuck open, normally it will leak gas
Jun 23, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
