Question about Garden
Troy bilt lawn mower
Riding mower: blade engages and works fine until you drop the deck to 2 or lower, then the blades no longer spin and it doesn't cut. Raise the deck, the blade engage again. The higher you raise it, the stronger the blade spins.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Posted on Jun 07, 2014
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
MIlfordPrint
  • 90 Answers
SOURCE: Mower runs but blades aren't turning
You can get help at both of these places:
http://troybilt.custhelp.com/cgi-bin/troybilt.cfg/php/enduser/std_alp.php
http://www.mowersdirect.com/technical-support.php
Posted on Aug 03, 2009
freetek
  • 5568 Answers
SOURCE: Troy Bilt 34073 mower - stripped spindle-shaft?
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
Posted on May 14, 2010
  • 23 Answers
SOURCE: The self propel on my 22" troy-bilt mower works
put belt dressing on the belt
Posted on Aug 17, 2011
BAMOUT
  • 2478 Answers
SOURCE: cub cadet 1040 blades spinning when pto isnt engaged
Sounds like you forget a spring or the routing belts are
wrong.
Posted on Sep 30, 2012
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
check to see if spindle bearings or bad or a bent or split pulley or bent or twisted deck or for broken lawn mower frame uallaslly around a weld frame twist deck belt comes off
Jul 10, 2013 | Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Gary
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
Blades lose power when deck lowered
SOUNDS LIKE YOU NEED A NEW BELT
Oct 01, 2009 | Garden
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
Self propel issue ????
The gear drops and lowers blade slightly until the gears are changed and engaged.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
192 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
