Question about Freezers
Ffu14f5hw High temp light on and sometimes flashes. Food in lower area thawed and top shelf temp approx 40. Freezer fan running. Pulled freezer out and placed fan to blow air over compressor, unsure if this changed anything. Temp later returned to 10 degrees on top shelf but lower section still above freezing. Turned fan off for the night and checked freezer in morning. Temp on top shelf still at 10 degrees and lower section still above freezing Removed cover inside freezer to expose coils and found light frost on upper half of coils and water dripping from lower section of coils. The door was found open slightly the day before.
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
refritech08
  • 149 Answers
SOURCE: FFU20FC6AW4
you said the coil was freezing up? have you checked your defrost element? if your handy with a voltmeter put it on the "beeping mode" (disconnect the fridge's power first) and test the element if it beeps its good, and means that the defrost control isn't working it could be a timer or a board, also check the freezer fan rotate the blades if it dosen't rotate the fan is stuck. if the fans turns out o.k, the defrost thermostat is defective (thats the little metal ball type control befor the heaters).
Posted on May 09, 2008
SOURCE: Can not get temp. below +10 f
what is your superheat and is defrost cycle working
Posted on Feb 28, 2009
tborn6
  • 700 Answers
SOURCE: upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Posted on Mar 28, 2009
heatman101
  • 43501 Answers
SOURCE: Freezer Temp keeps getting too high
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
Why are the sides of my frostfree freezer so hot?
check to see if you have a fan down by the compressor if so make sure it is running. if no fan you are starting to loose freon
Jul 25, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
Hotpoint freezer, High temp light on & all food thawing
It's probably the defrost timer is getting stuck in the defrost mode. What it does it it periodically interrupts power to the compressor and sends power to the defrost coils to allow any frost on the cooling coils to melt to keep them clear of ice build up. This is typically a mechanical timer and sometimes the motor fails and it stop turning and if it fails in the defrost mode, the compressor never turns back on no matter how warm the freezer is.
You can confirm it is the timer, by tracing the wires from the compressor to a little 2 by 2 inch box which is the timer. On one side there should be a round hole with a plastic cam. You should be able to turn that cam with a flat screw driver or a coin. Just give it a slight turn until you hear a click. After you turned the cam, the compressor should start. If it does, then it is the timer.
Jun 29, 2010 | Freezers
Top part thaws food the bottom half stays frozen. The freezer is 2 yrs old.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 06, 2010 | Danby 16.7 cu. ft. / 473 liter Upright...
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
Freezer control is on the highest setting and the inside temp is 40 degrees and most the food is thawed. what could be wrong?
you may have a bad compressor.also need to check the evaporator fan and see if it is turning. do you have any kind of frost build up on the back wall that you can see.the fan is located behind the rear panel in the back of the freezer if you your it running you may have a bad compressor
Sep 24, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Temperature goes up
do you hear any fans running?  by the temp staying cold on the drawers whih are in the lower area of the freezer it indiates to me that the fans are inoperable. to test open freezer door then push in light switch by hand and listen for the fans to come on. if it turns out you have bad motor you most likely will have to call a sub zero dealer to have repaired. messge me back with any questions peyton
Jan 28, 2009 | Sub-Zero Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
