Question about Carrier Heating & Cooling
Unit Control Manual for 580.75144700 - Carrier Heating & Cooling
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
You may download a copy of the manual at http://mypdfmanuals.com/dref/490349
Posted on Jul 13, 2013
How can i either modify my AC unit to work without a remote control or program a different remote control to be able to switch settings on my AC unit
What type of unit? Most units can be hard wired to a regular thermostat but you will need the owners manual to reset the program in the circuit board. The manual can be downloaded from the internet.
Jul 20, 2014 | Heating & Cooling
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
My Sony DVD/VCR player Model DVW-7200. I cannot get the remote to work. i can manually use the unit. Now i cannot find the operating manual. Isn't there a process to reset the remote control?
The only instruction manual I can find online for this model is for a SANYO DVW-7200 combo unit. This manual does not illustrate in any detail about remote control 'reset'; only the unit itself using remote to 'initialize' back to factory settings (except parental lock).
If the unit does not respond to the remote control;
Check if the power plug is connected to an AC outlet.
Check the batteries in the remote control.
Aim the remote control directly at the remote sensor. If necessary, remove all the obstacles
between the sensor and the remote control.
You have to be within 23 feet of this unit.
Check if the right mode is selected. If it's not in the right mode, press [DVD] or [VCR],
whichever you need, on the remote control.
Check if a cassette tape is in this unit.
Tune your radio to an empty AM station so that you hear a lot of noises. Turn the volume up,
then if you hear some signal sound from the radio in response to your pressing buttons on
the remote control, the remote control is working.
(the above tips come from the manual)
You can obtain a free pdf of the user manual for SANYO DVW-7200 (which is the closest to your model) and have a look through it. You can get it from the following:
http://www.retrevo.com/support/Sanyo-DVW-7200-DVD-Players-manual/id/311ag906/t/2/
Follow the prompts (it may ask for an email address), and enter the correct number code to download the document, then save the file. I don't know if it will help you or not, but worth a look.
This model does have a way to turn off progressive scan if it is enabled by accident:
press and hold [PLAY] button on front of unit for 5 - 10 seconds then release. This should revert the unit back to normal interlace (if required).
Apr 13, 2011 | Televison & Video
Washer does not complete a cycle. Error message E-07 pops up. drainage?
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
service and repair manual above use this service and repair manual to isolate and remedy your problem.
If you do not wish to DIY, please contact a Whirlpool service center and call them out, then ask for a "Quote" before allowing any work to proceed. . Motor Control Unit Error
The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
Aug 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Remote control unit displays error code 1250
Type " Leica 1000 Remote control user manual " into your computer search engine. It will bring up sites to go to get manual.
Aug 11, 2009 | Leica Measuring Tools & Sensors
I JUST WANT TO FIND THE DAM MANUAL FOR MY HEIL SUNDSTRAND OIL FURNACE A1VA-7012 CAN ANYONE HELP?????????????????
[PDF] 2100-016 (1976 11)File Format: PDF/Adobe Acrobat - View as HTML
Operate the manual reset button on top of control. ..... 19 Fuel Unit - Sundstrand A1VA-7012. 20 Fuel Unit Mounting Screw. 21 Oil Line Fitting ...
www.bardhvac.com/digcat/volume_3_cd/install.../2100-016.pdf
Jul 22, 2009 | Heating & Cooling
Control engine corrolla 1998
Prizms and Corollas are the same car, basically. If it will plug in and run the engine OK, I say go for it.
Jun 15, 2008 | 1998 Toyota Corolla
Heating & Cooling Logo
152 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
