Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Smells like human waste when I turn it on...Please help.
When using the vaccuum within 60 seconds you literally have to leave the room as the entire house smells like human waste. I initially thought it was the belt but the smell continues without the powerhead attached and just the metal nozzle. The water is fresh, the brush is clean and it sounds like normal. I would be greatful for any info!!
  • delmonte710
    delmonte710 Jul 13, 2013
    Vaccum was new 3 years ago and I have only used it 3 times since then. I just scrubbed out the water holder and replaced it with fresh water. The filter is WHITE as can be. I ran it with the filter cover off and the air blowing out the back stunk and the suction from the front was strong (I had nothing hooked up to it nor the hose or any attachments)
  • Rainbow Master
  • 18,408 Answers
4 Suggested Answers
provactek
  • 17 Answers
SOURCE: Rainbow e series smells burnt when power nozzle in use
Replace the belt in the power nozzle, it has to be changed yearly.
Posted on Oct 02, 2008
  • 11 Answers
SOURCE: how do i clean out the air filter on a E2 rainbow
You have to carefully remove the clear lenses that hold the labels in place on either side of the canister to get at the inner filter. I used two very small (about 1/8 in wide) screwdrivers at the bottom of each lens about 1 1/2 inches in from either side to pop it out. The lenses have 2 prongs on each side of the clip that extend into the vacuum about 1/2 inch, so be careful not to break them off when removing the lens.
Posted on Jul 03, 2009
  • 41 Answers
SOURCE: my rainbow e-series canister vacuum
Get a new hepa filter.
It is at the back side of it, behind that rectangular cover, where the exhaust cover is. It either snaps off with two plastic tabs on the bottom of it, or has two screws on the bottom of it, and two screws behind the cord holder taps thing. If it is that kind, the cord holder tabs thing, snaps off with a flat head screw driver on either side of it. You will see the little slots on it, if it is the kind with the screws on the filter cover. Two screws behind the cord holder tabs thing, towards the top of the filter cover, and two on the bottom of the filter cover.
Always clean your water separator with a tooth brush, or Rainbow separator cleaning brush. If it has it, it is by the water separator in a special slot for it, rite there by the water separator. If not, use a tooth brush. They are just alike. The separator nut, is a half inch, or 13 milimeter size of a nut.
Thank you,
Ralph
Posted on Jan 12, 2011
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Why does my rainbow e series smells like it's burning?
Belt for Power Nozzle EXCEPT the PN 12
or...
Motor Rainbow 120v
is most likely going bad. You can also call out technical support team if needed... Contact Us
RainVac
Jul 20, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow vaccuum e series will not turn on
Most likely the motor is dead, or the switch is bad.
Apr 30, 2012 | Rainbow E series Canister Wet/Dry Vacuum
There is a flashing red light on my rainbow e2 machine?
There is a flashing red light on my rainbow e2 and little smells bad
Dec 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Whenever i turn on my rainbow, it smells like dirty feet. i have cleaned the canitster, but it still smells and its coming from what looks like the plastic filter maybe?
there is a hepa filter on the back of unit, if you remove and than run the machine you can find out if that is where it is coming from. Most likely is.
Oct 17, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Oct 01, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series Canister vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=661549
Posted by tinyrose on Jun 10, 2008
I am looking for a repair manual for this vacuum. Just stopped working and will not turn on. Can you tell me where to get a manual? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The best way to get a Rainbow E Series owner’s manual is to contact the Rainbow website and or factory and give them the model and serial # for the item and you may be able to download the manual from the website or the might have to mail it out to your home USPS. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
296 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
