Question about Garden
How to replace the primer buld on a feather light weedeater
The bulb is incased in a plastics how do I get that part to replace the bulb that has cracked
  • 109 Answers
Chances are you have to get that hole piece as in cheaper models not service friendly
Posted on Jul 15, 2013
SOURCE: Primer Bulb not working on Weedeater!!!!
Sounds like the rubber bulb has a hole in it or it's leaking -- if you can tighten it, do so, If this doesn't work try replacing it.
Posted on May 06, 2009
SOURCE: I changed the fuel line going from the fuel tank to the primer bulb and now my weedeater will not stay running and my primer bulb is not holiding fuel.
Make sure the fuel line is a good fit to the carb. ... If is sucking any air at all it won't run right.. Also check that the fuel line in the tank is still hooked up...
Posted on May 21, 2009
canbruce75
  • 1776 Answers
SOURCE: toro weed eater gasline problems
The bulb should have two fittings. When you depress the bulb, air should **** in on one fitting and air should be expelled out the other. You may have the line from the tank on the wrong fitting. Hope this helped and best wishes.
Posted on Jul 31, 2009
SOURCE: broken primer bulb
home depot has a fuel system rebuild kit that includes bulb, filter, hoses all for less than 7 bucks.
Posted on May 06, 2010
SOURCE: Featherweight weedeater primer bulb repair?
featherweight weedeater - runs rough and has no power
Posted on May 28, 2011
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
My feather light is leaking fuel throughthe exaust how do I fix that Weedeater
Check the little plastic fuel lines for breaks or loose connections. If they are good, search YouTube for video on how to clean/overhaul the carburetor. Also make sure your primer bulb is not cracked.
Online parts stores will have parts diagrams to show were the fuel lines go.
Aug 31, 2014 | Cars & Trucks
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
What is the correct position on primer bulb for fuel lines
Short side of primer bulb to the carb and long side of the primer buld to the fuel tank as it's the return line.
May 05, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need to replace the primmer bulb
Hi lulutoto...
You will have to remove your carburetor from the trimmer to be able to replace the primer bulb.
NOTE: Before you disassemble the carburetor to replace the primer bulb:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
I highly recommend that you take the following actions if your going to replace the primer bulb.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Jun 29, 2011 | Craftsman 25cc Gas Line Trimmer
Jul 03, 2009 | Garden
May 06, 2009 | Poulan Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Relacing fuel lines in a weedeater blower/vac
Sounds Correct on this End.
Jan 23, 2009 | Garden
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
