Question about Rucanor Digimeter Pulse Motion Sensor Pedometer - Black
How to reset distance? - Rucanor Digimeter Pulse Motion Sensor Pedometer - Black
Is it at all possible to reset the distance to empty reading on the dash? 2000 linciln towncar cartier
Distance to empty is based on the average fuel economy for the last 500 miles driven. You can reset this by unplugging the battery to set it to default but that is the best you can do.
Mar 05, 2013 | 2000 Lincoln Town Car
York 2750 treadmill: How do I reset distance display? regards
Does anyone know where I can buy a replacement earlip pulse monitor for York 2750 treadmill?
Jun 27, 2011 | Health & Beauty
03 Range rover "engine service
Try this:
Switch ignition OFF
Press and Hold left instrument panel reset button, switch ignition ON to position 1
Keep reset button pressed for approximately 5 seconds until the LCD displays "RESET SIA".
The distance to service and the service type " Inspection" will be displayed.
To reset distance the left hand button should be pressed before the 'RESET' message has
flashed 5 times. The LCD will display 'END SIA'. Switch ignition off
The timing to do this is must be about 5 seconds, if this is not working you can try again.
Jun 21, 2011 | 2004 Land Rover Range Rover
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
The service engine soon light is on for my range rover 2004.
Try this:
Switch ignition OFF
I have a Range Rover 2005 and it worked for me.
Nov 13, 2010 | 2004 Land Rover Range Rover
How do I reset the distance ?
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
Apr 20, 2010 | Sportline C9 by Champion Fitness 910 Watch
2007 Lexus ES350. Mater Warning Light is activated for oil maintenence. How do I shut it off?
if you do not have navigation system.
  1. Turn the engine switch OFF..
  2. While pressing the trip meter reset button, set the engine switch to IG-ON mode. Continue to press and hold the knob until the trip meter displays 000000.
if you have navigation.
  1. Push the "INFO" button
  2. Touch "Maintenance".
  3. Touch the desired button Delete All : To cancel all conditions which have been input. Reset All : To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.
  4. Input the conditions. Notice of Date : The next maintenance date can be input. Notice of Distance : The driving distance until the next maintenance check can be input. "Delete" : To cancel the date and distance conditions. "Reset" : To reset the date and distance conditions.
  5. Touch "OK" The screen returns to the "Maintenance screen.
Mar 05, 2010 | 2007 Lexus ES 350
Resetting the distance on my Bell F20 bike computer
Did the same thing. Manual is incorrect. Hold only the left button for 3 secs. This will reset DST.
Jul 21, 2009 | Cycling
Reset distance mode in miles/not km
http://www.sportline.com/manuals/345.pdf
to change from km to miles or from miles to km... press and hold the reset button for (at least) 5 seconds (while in the distance mode.) This will reset your already walked info.
Jan 12, 2009 | Sportline 345 Electronic Pedometer
EVIC - PERFORM SERVICE MESSAGE
To reset the perform service message , is as follows , turn ignition switch to the ON position , depress and release MENU push button until SERVICE INTV . = is displayed , press and release STEP button to step through available options. the last selected distance option displayed becomes the service interval at which the PERFORM SERVICE message will be displayed . if a new distance interval is selected , RESET SERVICE DISTANCE ? with a yes or no option. when yes is selected the accumulated distance since the last previous PERFORM SERVICE message will be set to zero because the service interval has been changed . when NO is selected , the distance until the next PERFORM SERVICE message is reduced by the accumulated distance since the last previous message . EVIC exits programming mode and returns to its normal operation mode when the C/T button is depressed or when the end of the programmable feature menu list is reached , whichever comes first .
Thanks for asking .
Dec 30, 2008 | 2002 Jeep Grand Cherokee
Rucanor Digimeter Pulse Motion Sensor Pedometer - Black Logo
70 people viewed this question
Top Rucanor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Rucanor Exercise and Fitnes Expert? Answer questions, earn points and help others
