417 48102701 kenmore washing machine will agitate but will not spin the clothes to remove the excess water
My Kenmore HE front loading washing machine (417 48102701) will agitate the clothes but will not spin the excess water out or the clothes. I think the motor control board may be bad, but if this is the problem, where is the board and how do I replace it?
  • 213 Answers
SOURCE: front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Posted on Nov 20, 2007
watugot
  • 290 Answers
SOURCE: belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Posted on Dec 12, 2007
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
SOURCE: front loading washer won't spin
my amana washer wont spin and does not drain
Posted on Sep 12, 2009
  • 127 Answers
SOURCE: Direct Drive Kenmore Washing Machine will not spin
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking..
best of luck,
ttfn
Posted on Oct 25, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Spin cycle does leaves excess water in clothes
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 06, 2011 | Kenmore 22422 Top Load Washer
Kenmore 431423 won't advance cycle, won't agitate
not sure why he would replace the shocks this is clearly a timer/control issue. Replace the main control
Jun 11, 2010 | Kenmore 43142 Front Load Washer
Kenmore warsher, Model num 110.14202300, not drain or spin
The clothes too wet after spin cycle tells me that the water ump is functioning. If it wasn't, there would still be lots of water in the machine when the cycle ended. These Kenmores have the water pump mounted on one side of the electric drive motor and the transmission, drive shaft, and agitator on the other side. The transmission is fastened to the motor by a "coupler", a three piece assy that often breaks. This common failure allows the machine to complete a cycle, however, because of the broken coupler, there is no drive to the tub and no spin or agitate. The clothes seem wet because the spin motion is supposed to provide the force to extract the excess moisture. Leave the lid open and verify that there is no agitate or spin.(During spin cycle use a pen to press down on the safety interlock, a small opening on the the of the machine, toollow the unit to spin with the lid open). If you verify this, flip the machine over and locate the coulper on one side of the motor. One side will be cracked along the shaft. Sears parts stores carry the coupler in stock. ($18.50) Hope this helps.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Mar 24, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Machine not draining
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
It's slow to fill
It's overfilling
It's underfilling
Hope this may help;
Aug 10, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
